GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
Chet:
Thanks for the link to OUR and I know that there are good people there that know what they are doing.
The reason that I have pushed hard on this testing issue is because I have seen so many of these things degenerate into ridiculous farces.  I have also seen you become very passive in situations like this and it gets you nowhere.  It's very frustrating to see that.
With respect to the test specification, it is never simple.  You may have expertise in testing methods for buildings (or whatever you do) but that does not necessarily translate into testing for electronic circuits.  A spec is being developed at OUR and I am quite sure it will be very good.  The problem is that it is just a piece of paper or some bits sitting on a hard drive.  What guarantees do you have that Mr. GDS will follow your test protocol?  Right now I am assuming that there are none, and that opens the Pandora's Box for GDS to come up with a bunch of excuses.
You should give the document to GDS and have them generate their own test spec based on your document.  You should clearly have a complete picture of what will transpire when people go to GDS before they go there - from GDS themselves.  Get them to take ownership and produce their own spec based on the OUR spec.
Then do you know what is going to happen?  If they produce a spec that looks legitimate they will bow out at the last minute and call it off.  Do you know why?  The reason is that they don't have a magic box, period.  Tons of information is pointing in that direction and you don't want to look at it.  If they produce a test spec based on the OUR spec then they have no choice but to bow out because they won't be able to deliver.  They will make up an excuse like a sickness or a car accident or a death of a member of the family or a close friend.  You will have effectively smoked them out and they will run away.  That would be a victory for the truth.
I think TK put up the link for the guy from 2012 that was supposed to send a big lumbering box to Sterling that would power his house.  It never happened.  The same thing will take place with respect to GDS.
You can get annoyed as much as you want.  The only thing that I have to do is watch the clock run out.  There are no magic beans for a vine that climbs into the clouds coming from GDS.  They are a rank amateur bunch of clowns that can't string five sentences together about their alleged product that make sense.  And sorry, but you do deserve some flak for buying the lame excuses from the other two jokers.  You have to realize that in sincerely trying to do good on your part, you can easily become a facilitator for criminal activity.
Have GDS put their name to a test protocol before anybody considers visiting them.
DreamThinkBuild
Hi Chet,
Thank you for continued perseverance into the matter whether positive or negative.
Hi All,
If speculating at an easier design with less moving components this patent looks like it would use the full force of the pumped water.
Patent Application US2005/0103004 A1 - Velocity Intensifying power system
https://www.google.com/patents/US20050103004
MarkE
DTB how is that any different than the perpetual motion Archimedes screw water wheel machine designs that have never worked?
DreamThinkBuild
Quote from: MarkE on November 04, 2014, 02:10:37 PM
Hi MarkE,
Exactly, no matter how we arrange the equation it will end in equivalency.
Nink
I see how it works you plug a huge battery at 13.   Sigh!
