0 Members and 40 Guests are viewing this topic.
Farmhand
QuoteIt is good to see some one else spotted the scam.
Flux gate alternators put out very little power , and still have the same lenz force effect as any other alternator per watt output. The gate plates carry the magnetic field, and the lenz force acts apon the plates as if they were the magnets them self .I see some great minds on this thread falling for this rubbish.
Quote from: picowatt on November 12, 2014, 06:26:04 PM
Tinman,
Yes indeed, the videos are highly suspect.  Regarding the first video, the output driven relay idea sounds about right.
Ever use a wind up flashlight?  Upon listening to the first video, I was immediately reminded of the sound of straight cut gears being used to greatly multiply a shaft speed.  Also, when he stops turning the pulley, there is a cogging effect seen on the rim of the pulley as the" innards" of the machine apparently stop rotating.  Either there is a ratchet clutch, or just gears over riding each other, but something inside appears to stop rotating after the pulley stops and there is also a sound associated with that action.
When we are shown the voltage on the meter, the voltage swings up and down as he rotates the pulley.  Oddly, when the loads are attached and operating, no hint of a voltage fluctuation is observed, just full off or full on, never anywhere in between.
As well, we are to believe that when he shows the current using the clamp meters that there are supposed to be 2400 watts or so flowing through flimsy connections.  One might rightfully expect a bit of heat or smoke.
The drawings he has shown do not at all seem to be in accord with the mechanical action or sounds observed when he rotates the pulley by hand (i.e., the cogging or stuttering of the pulley when he stops spinning it and the associated sounds).
So, where do the 162 magnets go?
PW
Looks like something is buried in a squarish hole under one of the capacitors. I call hoax. Dirt floor square lines around the
capacitor supposedly powering the drive motor, the capacitor doesn't move at all.
And the operation shows the power draw reflected in the strain on the belt while using the welder, and is audible loading so the
load is being reflected to the supply.
Because of the low RPM operation of the generator (possibly for wind turbine) and also due to the gearing the load is not noticed
so easily, but I can see it loading the belt when he uses the welder and hear it.
What's under that cap and why is there a square indent in the ground that resembles something buried that vibrates maybe ?  :)
tinman
Quote from: Farmhand on November 15, 2014, 11:21:07 PM
I like how the motor and generator are bolted so soundly to the dirt lol
It is obvious that the motor and generator are bolted to a base plate of some description,as neither the motor or generator move when he struggles to remove the belt. You then have to ask--WHY did they cover it all up with dirt?
Enjoykin
Quote from: syairchairun on November 09, 2014, 09:05:00 AM
Hai, after i post myvideo about generator no effect lenz law, Now I will show U it can selfrunning, only use myhand to start,
and ths video i will show short coil and no efect lenzlaw, and I will show next mygenerator 10kva its same project, differnt only its has only 4pole run in 1500rpm toget 50hz, its same with mygenrtor 5kva, in mygnrtor 5kva i use 40pole stator coil in wire pararel,220v.0.5A 50hz percoil in only 100-120 rpm, but its very expensve i use 162 prmnen mgnet and it gve very high cogng when start.
In next plan mygenrtr 10kva i dnt use prmnen mgnet, only elctromgnetc ( 80v.4A exciter), and i dnt modfication coil in stator its original, and i use coupling 1 by 1 of motor and gnerator no use pulley or gearbox, they are expnsve,
And i will show the animation how to it work,
Next video : http://www.youtube.com/watch?v=SqWU12Db_MY
I think same it wth device James W german, But it linear flux magnetic but in Ramadan device is circular flux magnetic..
The key is magnet and stator coil not spining or rotate and rotr made by softiron rotate between them..
Thank's..
Halo syairchairun teman lama saya apa yang terjadi di indonesia.  :D
Bagaimana Anda generator. Orang-orang dalam bahasa Rusia menunggu Anda untuk memberi mereka petunjuk bagaimana membuat Genset Anda. Mereka membutuhkan informasi bagaimana kutub magnetik ditempatkan dalam perangkat. Bantuan kami giev semua diperlukan rincian dan kami akan membuat dunia ini lebih banyak terima kasih salam enjoykin
Menonton video baru Free energi magnet motor pada saluran TheMaster DV  :D
https://www.youtube.com/watch?v=PmbtVaVGxns
https://www.youtube.com/channel/UCrkiqE5FdlAZmSKeQe00i-w
ps: Кami menunggu bantuan Anda. berhati-hati dan keberuntungan. Saya telah membuat thread baru untuk Genset Anda situs free energi saya datang dan bergabung dengan kami teman kita Indonesia.
http://realstrannik.com/forum/svobodnaya-energiya/81-btg-10kvatt.html
Salam enjoykin Rusia  :D
Tinman and Farmhand have got it right. It is simply not possible for the two devices connected by the belt to maintain pulley orientation and tension on the belt while operating unless they are both firmly attached to the same mounting surface somehow. Hasn't anyone ever worked on a car with a slipping alternator belt? You need quite a bit of tension in order to eliminate slippage and squealing and you aren't going to be able to maintain that simply by setting your generator and drive motor on the dirt.
I'm not so sure the square indentation is a smoking gun, though. It could be the "footprint" of one of the heavier devices, that was set down there and then picked up and moved over. It looks to be about the same size as the base of the large blue generator housing.
