FatBird
This Brazil Captor unit is just FOOLING THE METER.If you Follow the Mains HOT wire (wire 1) down you can see that it exits the OUTPUT (wire 4).
This is the SAME MAINS HOT WIRE.They Fool the Meter because the Output uses the EARTH GROUND and NOT the Mains Neutral, thus FOOLING the Meter
However, I suspect that their units CANNOT fool the New SMART Meters being installed around the world.The coiled Black Wire serves NO useful purpose
EXCEPT to show around 125 Amps circulating in itself.  EXCELLENT for fooling people though.  LOL
---->   A VERY SPECIAL THANKS goes to Mr Ariovaldo for BUYING a Captor, taking it apart, and Drawing the SUPER GOOD Professional Schematic.
pomodoro
Quote from: Zeitmaschine on December 15, 2014, 09:50:20 AM
Absolutely SURE. The primary should be connected to an inverter and a 12V battery. So the 12V DC (!) ampere measurement is accurate to the mA. Don't measure the AC on the primary directly, it is completely messy due to the sharp spark pulses.
I would only trust that method of measurement if the power drawn from the spark  is greater than the quiescent no load input to the inverter. Not an easy thing to do as the capacitance of the metal object will only be a few pF.
allcanadian
@Fatbird
QuoteThis Brazil Captor unit is just FOOLING THE METER.If you Follow the Mains HOT
world.The coiled Black Wire serves NO useful purpose EXCEPT to show around
When I first saw the patent that is the first thing I noticed, I thought they do know the neutral conductor is bonded to the ground plane don't they?. I seemed very obvious and this is the standard in North America I believe...is it in Brazil?.
AC
forest
Quote from: allcanadian on December 15, 2014, 12:13:33 PM
@FatbirdWhen I first saw the patent that is the first thing I noticed, I thought they do know the neutral conductor is bonded to the ground plane don't they?. I seemed very obvious and this is the standard in North America I believe...is it in Brazil?.
AC
ha ! allcanadian, did you lost hope ?
allcanadian
@Forest
Quoteha ! allcanadian, did you lost hope ?
Forest... I thought you knew me better than that.
AC
