0 Members and 66 Guests are viewing this topic.
Jimboot
Quote from: Mister Caribbean Roots on January 11, 2015, 11:10:37 PM
Hi Chet,
Thanks for the link... ;D
What stands out in his setup and what i liked about it is,
1- The full circle of magnets..just like a multi pole ring magnet... 8)
2- The full circle of the core...just tiny gaps between them... 8)
These 2 help to reduce the cogging a lot... 8)
If these 2 are open with large gaps you will have massive cogging like i had in my first flux gate setup running very poor at 10amps input...lol... :'( :-[ ::)
The mags are not gapped. They are attached to a piece of iron pipe and the dark lines are just made with a marking pen for measurement purposes.
wattsup
@MCR
As always, your workmanship is top notch.
I think a very good test is if you have two identical magnet wheels with the same polarities facing outward on both wheels. Then put the output coil in between the two magnet wheels and adjust the magnet wheels off angle so that one side hits the coil, then the other side and so on. So you have the same polarity hitting the coil in succession. This is where you should start to see output in multiples.
Also, in your last video have you tried it without that big speaker magnet to the left but with the same wheel  on the right to show difference between with and without a constant bias?
wattsup
Grumage
NoBull
Quote from: Grumage on January 12, 2015, 09:42:19 AM
Pick the bones from this !!  :)
First of all, the conductivity of the iron pieces will allow large eddy currents to flow in them.
Secondly, these is no low reluctance path for the return flux.
Grumage
Quote from: NoBull on January 12, 2015, 09:47:34 AM
Dear NoBull.
Noted !! This is perhaps why my beautifully engineered rotor warped !!
The Mk2 is already underway, I am having some laminated segments being surface ground, within the next few weeks, I hope ??  And I have some 8 mm Polycarbonate sheet on order for the new rotor.
I am hoping we shall see a number of improvements to the overall design !!
Cheers Grum.
