crystal radio: the first real free energy device
Started by franco malgarini, February 16, 2015, 04:52:26 AM
pomodoro
Uranium is not dangerous externally - just don't eat it or breathe it in! Same as the americium. Am is like a modern day radium, but you can't get much out of the detector.
Profitis, I have not doped anything as yet. Still getting to know the normal galena first.  The first melt attempt leaked out of a stainless tube at 1250c. The tube had a flat bottom which I thought was an integral part, but obviously wasn't.
Lakes
At the mention of Radio Active material I was reminded of the boy who built a reactor out of smoke detectors.
http://en.wikipedia.org/wiki/David_Hahn
profitis
Pomodoro:'Still getting to know the normal galena first.  The first melt attempt leaked out of a stainless tube at 1250c. The tube had a flat bottom which I thought was an integral part, but obviously wasn't.'
Chekout the meltingpoint of PbTe2: 940 celcius.it might also be worth a try.I've made it plenty times by just meting pb and te together until reaction initiates.its same family as galena
pomodoro
Not sure if I've got tellurium.  I did end up filling the can of a 2n2222a with UO2.  The top of the can is easily 'opened' by filing it away. IThe filing actually files away only at the edges leaving a small disk, which can be replaced back on top after the yellow  powder is put in the can. A bit of glue does the rest. I haven't done any testing of that as yet, apart from measuring the Vbe and Vbc voltage drops, which remained the same.  Using it as a diode in the crystal set was not too good, as expected. It needs to be used as an audio amp as in the Moreland patent. I'm making all the items first and testing them later.
profitis
Pomodoro:'I did end up filling the can of a 2n2222a with UO2.'
You may get small effect like this but I doubt it will be registerable.can hardly wait to see actual doping results.doping should theoreticly have orders magnitute greater effect
