FREE ENERGY =Electricity Multiplier
Started by that-prophet, December 29, 2014, 11:08:46 AM
that-prophet
free energy is super simple
you put DC power into a motor with a 100cm circumference pulley on it
you attach a belt, strap, rope or even a string in a pinch
and then attach at least one AC motor to a 1cm pulley on the same belt
you run the AC output through a full wave bridge rectifier to self power...
your DC input motor,,,,
then you have just created your first free energy electricity multiplier
satan will try to complain about torque, but it is no problem, just think about how easily an electric motor rotates,,,
you could have 10 - 100 AC motors attached, multiplying your input by 1000 - 10 000..
now dont you think this much output power could turn your input DC motor
FatBird
Your idea is so OUTRAGEOUS that NOBODY is even answering you.  LOL
that_prophet
FREE ENERGY IS A GIFT TO ALL = the simplicity of electricity multipliers
From this simple guy, to the whole world. Please take this burdon off my hands..
COME ON GUYS + GALS
Let's get with the program
(Electricity Multiplication using simple geometry to multiply rotations)
(which is easily converted into the multiplication of AC electricity)
Why use oil products, which contaminates our atmosphere,
Or use nuclear fission, where you have to deal with radioactive material, and even worse, it tends to leave nuclear bomb-making by-products
THIS WORKS, and it is so logical, that anybody can see it simply MUST work
(Let's use this to not only restart our economies + help our environment)
(we should help redistribute this new found wealth, to the lower classes)
(that we can all give generously, helping the many fantastic charities out there)
FREE ENERGY IS SO SIMPLE THAT WE HAVE MISSED IT = (why?)
. . I cannot believe how much of a hold that scepticism has on our society,
and it amazes me that people won't believe in how simple free energy is.
They hold on to this imaginary torque problem, which does not truly exist.
Think about it this way, how easy is it to rotate a mini-electric motor,
with now-a-days electric engines; they are the easiest to turn over.
. . We only have to put a miniscule amount of DC electricity into this system
to rotate your input motor one single rotation. This drive motor rotates a 100 cm circumference pulley one single rotation, which only takes an extremely small amount of DC electricity. It practically takes nothing to turn over your motor the once,
More so voltage, with practically no current. You are surely gaining massive amounts of AC electricity here, like 100 units of AC electricity for every single rotation of your input DC drive motor. This is why I call this an electricity multiplier, 100 units of AC power, for I unit of DC electricity..
. . This minimal amount of DC electricity input uses simple geometry of pulley size change to multiply your number of rotations, or AC electricity. This is done by driving a large pulley attached to a belt, that connects to one or as many as you like, miniature output pulleys attached to AC motors. These motors only have one centimetre circumference pulleys connected to them. These extremely small output pulleys rotate 100 times, producing 100 units of AC electricity, for each pulley that you attach. If you only had 10 mini-pulleys connected, you would have 1000 units of AC electricity as an output, for every single rotation of your input motor, to be put through a full wave bridge rectifier + voltage regulator, and then back into your DC motor, which is only expending a small amount of DC electricity, to rotate your drive motor the one single revolution.
. . You might hear the idiotic argument about torque, but if you just think about our electric motors now days. They are the easiest to rotate, and take practically zero torque to turn over, so torque is in no way a problem. These AC motors/generators take so little effort to turn, that you could easily have tens, maybe even hundreds of them attached to your belt. that your Free Energy Machine = Electricity Multipliers, might be This would mean in the order of hundreds or thousands of power. As in, you only put in enough DC power to make the 100 centimetre circumference drive pulley turn one single rotation, which is an extremely small amount of electricity. You get out of this system 100 units of AC electricity, which is easily much more than enough to get the drive motor to only do one rotation. You now have yourself an AC electric generator, which will not only power itself, which takes only a couple of your 100 AC units of output, leaving the other 90-98 units of AC output to be for external use. Please remember that these few units of AC electricity, are taken from only one of your AC generator, of the ten or more mini-pulleys that you can easily attach to the same belt, strap, rope or even string in a pinch.
. . You are simply using pulleys to multiply rotations, which multiplies your AC electricity. A simple diagram and explanation of how simply this works is at this URL address; http://free-energy.yolasite.com/ which I published many years ago, meaning that there are no royalty fees to pay, as I chose to have this as a truly FREE ENERGY GENERATOR. This one rotation of a 100 cm circumference pulley, when run through a simple mechanism, with a belt, strap, rope or even a string in a pinch, is then connected to one or more mini-pulleys of one centimeter circumference. This simple mechanism gives you 100 units of AC electricity, for as many of these mini-pulleys you choose to attach. .
NOW PLEASE take this mechanism and run with it,,,,,,,,,,,
This could help STOP TERRORISM
by taking away their money that they get from all of the oil that we are buying
and only needing oil products for lubrication
I also believe that I have these two amazing gifts for all video game enthusiast
One is a next generation joystick at http://ultimatejoysticks.yolasite.com/
Two is a 3D virtual reality games room at http://ultimatevideogamecontrols.yolasite.com/
But one of the best parts of these gifts is the way that both of these gifts could be used in other ways, as equipment for the disabled, and tools for safe ways to do very dangerous jobs, from the safety of video rooms, set in most any place of safety.
For the ultimate Joe-stick, we could build them to measure whatever few movements that the disabled person could perform, and program it to do whatever movement that they would like to do, like typing or speech, or whatever movement that you would like to program into it. http://ultimatejoysticks.yolasite.com/
For the ultimate video game controller, we could have it simulating robots, that are in deep space, or any depth in the water, or in some extremely dangerous places, like at chemical spills, radioactive sites, or even sites of fires. http://ultimatevideogamecontrols.yolasite.com/
These are all free for all to use, as they have been published on the web
+ are without patent fees of any kind
Paul-R
Quote from: that-prophet on December 29, 2014, 11:08:46 AM
What are your "Energy In" and "Energy out" figures?
Pirate88179
Yes, the newer electric motors are easy to turn thanks to decent bearings...however, under LOAD, which these will be (Lenz Law) you will find them very resistant to turning indeed.With this law in mind, your design can not work.  (In my opinion)
But, go ahead and build one and see for yourself?  Let us know how it works out.
Bill
