Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: tinman on March 31, 2015, 09:56:16 AM
And why do you think that?. If you knew what was happening,then you would understand as to why the rotor speeds up when a heavier load is placed on the coil/inductor. A heavier load means a greater current,which means a stronger magnetic field,which means a greater attraction or repulsionforce (depending on wether it's a repulsion or attraction motor setup)  on the rotor magnets.
Consider this-->current follows the path of least resistance.
@Tinman,
My guess is that the stronger magnetic field raises the ferrite core to the saturation point. This may in turn slow the electric current flow down in the coil windings and delay the pole shift causing reverse Lenz propulsion. This effect perhaps couples with and augments the effect you highlighted. Skycollection generates a huge amount of very bright light with merely two tiny AA batteries. I'm extremely impressed. I don't believe all that illumination comes from just the batteries alone.
Arthurs
Quote from: synchro1 on March 31, 2015, 01:51:43 PM
@Tinman,
My guess is that the stronger magnetic field raises the ferrite core to the saturation point. This may in turn slow the electric current flow down in the coil windings and delay the pole shift causing reverse Lenz propulsion. This effect perhaps couples with and augments the effect you highlighted. Skycollection generates a huge amount of very bright light with merely two tiny AA batteries. I'm extremely impressed. I don't believe all that illumination comes just from the batteries alone.
Not underestimate the 'AA' batteries,
[DURACELL] of "AA" battery has a capacity of at least 1700mAh,
Two "AA" batteries can provide more power 3W.
synchro1
Quote from: Arthurs on March 31, 2015, 03:41:41 PM
@Arthur,
Big deal. That might illuminate a porch light. Skycollection's generating enough brightness for an overhead chandelier.
By the way; You should take notice of Skycollection's S-S N-N magnet positioning in his latest video schematic. You failed to label your magnet polarities. I am assuming they're monopolar. I stressed the major importance of generating a pure AC sine wave, as Skycollection does, to maximize the full capabilities of the "AC Tesla Bifilar Pancake Coil".
This kind of signal is essential for the inductive coupling effect, along with the correct "Ensemble" described by Skycollection in his PDF.
Quote from: skycollection on March 31, 2015, 01:21:44 AM
I post this video and the circuit for my pancake coils and a pulse motor-generator with 2 AA batteries...!
https://www.youtube.com/watch?v=do5xtmfMRxI
Jorge:
I looked at your clip.  I don't know why you would call it "Serious OU Potential Pulse Motor."
It's important to not lie to yourself when you make experiments.  This is a problem that you see everywhere on the forums.
Here is what is going on in your clip:
Input Power:
Two AA batteries.
Output Power:
Oscillator circuit (heat)
Three LED lights from coil pickup  (light + heat)
One LED light for back-EMF connection (light + heat)
Spinning rotor (heat)
Electrical losses in wires and coils (heat)
If you could make proper measurements then the input power would be exactly equal to the total output power.  That is the truth, and that is the reality.
There is no reason to make a false claim like "Serious OU Potential Pulse Motor."  There is no evidence for this.  You end up lying to yourself and your audience when you do that.
It's impossible to make measurements of the electrical power going into the LED lights because you would need an expensive digital storage oscilloscope to do that.
In the final analysis, the truth - la verdad - is an important thing that we all should not forget.  I am not trying to stop you from having fun with your experiments, just be truthful to yourself.
Pirate88179
No disrespect intended but a good High Voltage JT circuit can make more light than that with a single "dead" AA battery.  Also, the HVJT is not OU.
I don't see the utility of this circuit at all.
Bill
