Hot Fusion At Home?
Started by gammarayburst, March 31, 2015, 01:07:31 PM
LibreEnergia
Quote from: gammarayburst on March 31, 2015, 08:07:20 PM
The fuel is (deuterium oxide (2. H 2O ) or D 2O) [/font][/size]
If the fuel was the size of a small marble and the sphere was one foot in diameter I think it would hold it long enough for all the fuel to burn. [/font][/size]
No, it's not an April fools joke. I plan on building a 1 inch diameter sphere for testing.[/font][/size]
Butch[/font][/size]
One of the reasons fusion has proven so elusive is that there are NO materials that can withstand the temperatures and pressures required to contain a plasma at the energies required.
That's why they use magnetic (such as ITER) or inertial confinement (such as NIF).
You're just dreaming if you think any amount of steel can do the job.
gammarayburst
Quote from: LibreEnergia on March 31, 2015, 09:08:08 PM
That's the point of it! The very small amount of fuel, half an ounce and a one foot diameter sphere will self destruct but in the time it takes a portion of the fuel will have burned.
Butch
Pirate88179
Where are you going to get, or how are you going to make the heavy water?
Bill
gammarayburst
Quote from: Pirate88179 on March 31, 2015, 10:15:47 PM
Bill
Special note > Inertial electrostatic confinement[edit]
Main article: Inertial electrostatic confinementInertial electrostatic confinement is a set of devices that use an electric field to heat ions to fusion conditions. The most well known is the fusor. Starting in 1999, a number of amateurs have been able to do amateur fusion using these homemade devices.
Bill, if an eight grader can get it, I can.
LibreEnergia
Quote from: gammarayburst on March 31, 2015, 10:10:19 PM
Butch
For fusion to be useful the amount of energy released needs to be more than the energy input. No physical containment, and certainly one made of any amount of steel will allow that to occur. The temperatures are simply too hot. The containment is destroyed  causing the fuel to stop fusing before energy break even is reached.
I'd hope you'd realise the amount of energy released in destroying a one foot steel sphere might exclude it from being the sort of experiment you'd want to try at home...
