Ha ha Bill, you forgot to mention that you have to also jump up and down and rub your belly at the same time to get OU from the white wire.
Chet, being the nice guy that he is, linked to the US geomagnetic map.  Chet is not technical, but let's continue the technical discussion about this here.
I am totally out of my element, so take that into account.  The map is attached.
I did some digging.
The World Digital Magnetic Anomaly Map (WDMAM) shows the variation in strength of the magnetic field after the Earth's dipole field has been removed. Earth's dipole field is generated by circulating electric currents in the planet's metal core. It varies from 35,000 nanoTesla (nT) at the Equator to 70,000 nT at the poles.
1838, Carl Friedrich Gauss proved 95% of Earth's magnetic field is internal, 5% external
    Earth's field is sum of 3 parts:
        Main magnetic field
            produced by electrical currents in outer core
            steady on time scale of days, but variable over years
            approximately 50,000 nT (0.5 Oe)
            accounts for large regional variations in intensity and direction
        External magnetic field
            produced by electrical currents in ionosphere consisting of particles ionized by solar radiation (11-year solar cycle)
            usually variable over hours, at tens of nT
            occasionally variable over minutes, at hundreds of nT (magnetic storm)
        Anomalous, induced magnetic field
            magnetization induced in crust by Main Field (and External Field) or remanent magnetization ("permanently induced")
            limited to upper crust (Curie T)
            limited to ferr(o,i)magnetic materials
With fairly good confidence I can state that the geomagnetic map is just a map of the very slight differences in the strength and direction of the Earth's magnetic field at the surface because of the remnant magnetization in the underlying bedrock, different bedrock materials, deposits of iron, etc, etc.
That's what I basically said in a previous posting without having looked anything up.
Conclusion:  The geomagnetic map is absolutely useless to this "project" and will not affect anything in any way, shape, or form whatsoever.
If anybody disagrees with me and has an argument to put forth please do so.
This is one of the great pitfalls of this forum.  It's to "buy in" to junk useless information, pretend it has value, and pretend you are using the information.  But when push comes to shove and "you" are put on the spot and asked why, "you" have nothing to say.
Now take a look at this exchange between Clarence and Dielectric on EF:
Originally Posted by dielectric:
I'm not trying to make you repeat yourself here but... you have 60 (sixty) 8 foot long rods pounded all the way into the ground, hooked up in series and THIS is what formulates your grounding grid?
Would you suspect that someone in a geomagnetic "hotzone" would need far less rods than that?
Thanks!
Hello again,
yes I have 60 rods pushed - not BEATEN - in a linked 3 foot spaced series which loops back to itself and this is what makes my Ground RETURN Grid. at a single point at a rod adjacent to my house entrance, to that rod I attach my earth neutral wire lead ( # 6 AWG) that leads directly to my Captor loop you see in my photo of the unit. from my inverter NEUTRAL I also have a # 6AWG wire lead that goes out side to a separate open ended 3 foot spaced series of 4 rods as the GROUND GRID INPUT.
with reference to the " hot zone " a builder should need less than I did for certain. how many you will have to determine for yourself. I tell you how to know in previous posts.
thanks
Clarence
There is no such thing as a "geomagnetic 'hot zone'" - both Dielectric and Clarence are making up crap as they go along.
I have no tolerance for pseudo-scientific outright bullshit, and neither should any of you reading this.  Clarence shot himself in the foot by making up a fake answer for something that he almost certainly has no understanding of.
The question didn't make any sense, and the answer didn't make any sense.  Garbage-in-garbage-out. Save your money and your time for something else.
Pirate88179
Quote from: MileHigh on April 21, 2015, 09:44:38 PM
MH:
But, one more turn of that white wire, or one less could be why no one has been able to replicate this device yet. The number of turns here could be critical.  Also, you need the correct wire.  Black wire will not work.
Bill
PS  That white wire looks a lot like 5 conductor phone line complete with modular jacks. (RJ-14?)
memoryman
You forgot to mention the purity of the copper, as well as the phases of the moon.
So Clarence has 60 ground rods pushed... not BEATEN, but pushed... into the ground in his yard?  I just have one question:
Who mows his lawns?
(That map is interesting. Do you want to be where the field is strong? Then the Upper Peninsula of Michigan looks like where you want to be. I've heard the mosquitoes there are the size of small sparrows. And I do believe it gets rather cold in the winter. But the ice fishing is supposed to be good.)
If you are lost in the woods, and your cell phone battery is dead, and you have an emergency sewing kit in your backpack....
