Using geometry to multiply rotations = multiplying AC electricity
Started by that_prophet, January 12, 2015, 08:06:05 PM
that_prophet
Come on guys
Let's get with the program
This works, and is so logical that it must work
You put a very small amout of DC electrity into a motor
That has a large 100 cm circumference pulley + only has to rotate once
Then you use a belt or strap to connect it to one or more mini pulleys,
That are of 1 cm circumference, which rotate 100 times + have AC motors
So you put in 1 unit of DC electricity
To gain 100 units of AC electricity = 50 – 100 electricity multiplier
please remember, you could add many mini pulleys
multiplying your electricity by massive amounts
dont listen to satan`s torque arguements
think of how easily mini motors turn
it takes practicallly no effort
This is not only free energy from God =(Eze 1:16)
DIAGRAM + DISCRIPTION @ http://free-energy.yolasite.com/
So, not only do we know free energy as Truth, but it is also good news in 2 tways
1) This will take away massive sums of money given to nations growing terrorists
+ This is info from The Big Guy Himself, so
2) This was found as a description of the workings of a UFO, so we should be able to discover antigravity, or be able to figure what ever helps these UFO'S levitate + travel so fast
(EZE 1:16) The appearance of the wheels and their work was like unto the colour of a beryl: and they four had one likeness: and their appearance and their work was as it were a wheel in the middle of a wheel.
as in, a little wheel inside a big wheel, but I could not afford to buy a big wheel with threeding on the inside, and a mini wheel with the same threeding on its outside. So I did the next best thing, I connected a big wheel to a mini wheel through a belt, stap, rope or even a piece of string in a pinch to connect the two pulleys with motors attached. This was easier to build out of many parts that one might have around, especially for the Tribulation Saints, when they are running from the evil authorities = in less than 5 years. http://my2020vision.yolasite.com/
Please remember this, when before 2020 the Tribulation starts = 7 year peace treaty signing with Israel = START OF TRIBULATION
Please view all the info that I have picked up @ http://beliefstoliveby.yolasite.com/
He gave me these two other Gifts also @ http://ultimatejoysticks.yolasite.com/
(an awesome next generation joystick = measures movement in all three axis's + measures rotations in all three axis's = that's 6 movements = 3 times basic joystick) -
AND http://ultimatevideogamecontrols.yolasite.com/
(which is awesome 3D virtual reality room = video on all 4 walls + ceiling + floor )
These are all free for all to use, as they are displayed on the web + are without patents
We should use these to earn plenty of income to help http://fire-starter.yolasite.com/ spread the Gospel.
Before http://my2020vision.yolasite.com/ occurs, before the
Door closes on Christ return http://doorschristmustpassthrough.yolasite.com/
Now first off let's loose this fairytale of EVil-sOLUTION
God proves it wrong with His Creation Hourglass = MOON= it only has 6000 years worth of sand on it,,,,,,
http://decimationofthisevolutionfairytale.yolasite.com/
free energy
The only reason that this has not been used earlier to create free energy, are the billions of fallen angels, trying desperately make sure that we never discover this technology
LibreEnergia
Quote from: that_prophet on January 12, 2015, 08:06:05 PM
...dont listen to satan`s torque arguments...
So you're telling me satan is all torque and no action?
dieter
Regardless of the religious aspects, there is something interesting about this topic:
While the translation with pulleys and belts to achieve a multiplication of the RPM  can be done at the cost of losses like friction etc. , the increase of frequency in AC is indeed equal to the increase of energy. Is there a flaw in this thought?
BR
that_prophet
Quote from: LibreEnergia on January 13, 2015, 04:04:13 PM
NO,,, what I happen to be saying is that there is no torque problem,
you are gaining so many rotations from the mini-pulleys,
that the torque is divided up into almost nothing
I happen to be struggling with an electronic simulator at the moment,
trying to get a working model of the awesome free energy machine that God Shared with me,,,
I believe that He wishes for this to be priority for me,
it is so simple, and easy to build,
could I ask for help getting a working model of this device out to the world,
evil forces have put up barriers for me at every turn,,,,,,,,,,,,,,,,,
THIS WORKS, IT IS SO SIMPLE THAT IT HAS TO WORK
this device generates AC electricity by using mechanics of varying pulley sizes to multiply rotations,
generated additional AC electricity by using multiple generators
Free Energy made simple = electricity multiplier using 100cm to 1cm pulleys
Don't believe in God or good + evil forces
Free Energy is so simple,,, that it MUST be hidden by evil forces.
It is simplicity at its best; you simple put the minimal power into a DC motor with a 100cm pulley connected to it, which only has to rotate the once. This large pulley is connected to a belt, strap, rope or even string in a pinch, which is also connected to another small one cm pulley, which rotates 100 times. So you put in the DC power to rotate your input motor only the once, and you get out of this system 100 cycles of AC power. You have just created your first free energy machine, that multiplied your electricity by 50 or 100. If anybody starts complaining about torque being a problem, just think about how smoothly bearings are nowadays, as well as how easily electric motors rotate. You could add ten of these small pulleys, without gaining any sufficient torque, giving you a 1000 power electricity multiplier.
A drawing and better description of how this works is at:
Please believe me + not all of the evil spirits
That are continuously saying, "this won't work"
Free energy is super simple
It has been staring us right in the face
Ever since we discovered how to make AC electricity
How is AC electricity made?
It is simply made by rotating wheels
With these wheels connected to an AC motor
Which is easily created, by using a few coils of wires
And rotating them within the field of two opposing magnets
They will try to say what about torque
Torque is not a problem in the slightest,
As electric motors are the easiest to rotate
They have some of the smoothest running bearings
So you could add tens, maybe even hundreds
Of these AC motors, attached to mini pulleys of one cm circumference
On the same belt that you have a DC motor attached to as a drive motor
With a large 100 cm circumference pulley or even larger
So you only have to input enough electricity to rotate the drive motor one rotation
Then you get 100 cycles of AC electricity out of this system
For every mini pulley with an AC motor attached that you connect to the belt
If you think this idea came to you from God, you are profoundly mistaken... or perhaps your God is just lying to you. Six threads! The same copy-paste nonsense in SIX threads!
