Vaccinations; recent developments
Started by SeaMonkey, December 01, 2014, 02:12:40 PM
Farmhand
Quote from: Pirate88179 on April 24, 2015, 10:44:23 PM
Hell Joel, my last computer which was 8 years old was running at 4.2 GHz.  I do not want to overdrive this one too much.  This speed is fine for it with no heating problems.  No water cooling or any exotic cooling methods required.
Sorry you do not understand how to do this as evidenced by the fact that you don't believe me.  No great feat really, my CPU stock runs at 3.4 GHz and it is 64 bit.  (I hope you understand what that means...if not...look it up)
The simple fact that you do not realize the importance for epoxy in building a decent computer tells me you know nothing and trying to answer all of your simple questions would be nothing but a waste of time.
You don't even know how to run at 4.6 GHz so, this tells me a lot about what you do not know.
I do not know how to unlock smart phones as I do not use a smart phone.  That is fine if you want the NSA monitoring all of your communications but, in my business, it is better to remain black. (Again, look it up if you do not understand)  My phone can not be monitored...let's just leave it at that.
Bill
From Vaccinations to overclocking computers, awesome. Nice drift.
So Bill, you like to overclock your computers as well hey. I have a socket 939 AMD Opteron 165 X2 (default speed 1.8 Ghz) and I overclocked that to 3.5 Ghz, I just fell short of the double speed or 100% increase. I did that in three different motherboards two Asus A8R32-MVP's one was the A8R32-MVP Deluxe and also on a Sapphire PC-A9RD580 PURE crossfire motherboard. The memory was Mushkin DDR 500, can't recall the settings exactly, but I intend to relive the past and rebuild that computer, very soon on the Sapphire board. And I will get CPU-Z shots ect. I had shots of when I did it back in 2008-9 uploaded to an overclocking website but I cannot find the post. I just bought some cheap AM2+ parts and will be building a slightly newer overclocker-gaming computer for windows 7 ect. games (3d shooters and simulators). I bought a dual core Athlon II 245 (standard speed 2.9 Ghz - can overclock to 3.5 stable or more (going on the info I have), I'll try for 3.8 Ghz. It runs DDR2 ram and I have DDR2 1066 ram for it.
Which allows me to set the bus speed to 400 for a default ram speed of DDR800 then when I increase the bus clock on the "Locked multiplier" CPU the ram speed can increase without going over it's rated speed as I overclock the cpu, first I find the maximum cpu speed, then I adjust to find the maximum ram speed and fastest or best timings for the ram without pushing the cpu over it's fastest stable speed.
I expect that the older 939 setup overclocked to 3.5 Ghz will be faster at cpu and ram operations than the slightly newer socket AM2+ at the same speeds as it has lower latency ram. However the AM2+ has a higher possible hyper transport link and bus speeds, so it'll be an interesting comparison, I even have two matching cases to build them in. Biggest pain is getting windows XP installed with all the hardware drivers properly installed. I think I can get them all still.
It all depends if I damaged any of the old parts, as I was experimenting with my Tesla coil very close to where they were stored.
The computer I'm using now has a Athlon X2 6000+ and standard speed 3.0 Ghz but the 6000+ cpu won't overclock much so it's not worth it, I use this one at standard speed.
ocerclocked computers seem to work faster than computers not overclocked at the same speed. Likely because of the overclocked setup using more power, and having the memory timings and settings "tuned". I also used to use 2 HDD's in RAID 0 mode for increased System disk speed, but now we have Solid State Drives for that bottleneck. Yay  ;D
Some cpu's don't like to be overclocked and some don't mind too much and a small number of cpu's seem to like being overclocked. Some cpu models have cpu with different stepping codes and some will overclock better than others even of the same model and type, just made at a different place or time.
P.S. Some Vaccinations are harmful some not so bad. I'm surrounded by people who have had the flu vax but I don't get the jab or the flu so I'm cool with that, I take the tetanus jabs when I get messy injuries. Just to write some on topic stuff for fun.
joel321
QuoteThis sounds like they walked into a doctors office and walked out with an Adderall prescription.  That is pretty unlikely.  Diagnosis requires the doctor establish a pattern of behavior that is atypical for their developmental level.
Yeah well there are doctors that operate on the wrong side of the leg or leave tools inside the patient. THAT"S HOW STUPID SIMPLE IT IS FOR DOCTORS TO OPERATE! THE HUMAN BODY HEALS ITSELF NOT THE DOCTORS HEAL THE BODY!
You make it sounds like medicine works 100% when I have asked you time and time again simple questions, what is the cure for the flu virus? Yet I know you have no answer because 100% there is none. I already told you that prevention is the cure just as you would not step on a land mind and loose a foot, IT IS NOT A MATTER OF REPEARING A LOST LIMB BUT RATHER PREVENTING A LOST LIMB IN THE FIRST PLACE!!!!
To put it simple, the only way we know about viruses that cause death is after someone dies, plain and simple. If it was the other way around, there would be no human dying from viruses ever again. The virus specialist are only DOING what they can and are overwhelmed with billions of viruses and math viruses combinations that what can do best is "understand" one STRAIN at a time where at the micro level, "evolution" changes so rapidly that they have no CHANCE to know EVERYTHING. Heck, there could be viruses that mutate every day, how to "cure" those if a human has one of those? HMMMM let me think!!!! Well here is a NEVER BEFORE ida...hmmmm,...How about prevention? IOW, no medicine to cure the virus if it never enters the body? Well, is not that LOGISTICS?
If a virus is moving at the speed of light, let me see you find a "vaccine" in your lab on a rat or monkey? How to see a pattern in a virus moving at a speed of light "evolution?
To get back to the article, let me hear how would you DIAGNOSE an ADHD patient? And after the diagnose, how would you "cure" the patient? Name any pill, any drug, the Goal is to cure! But first you have to define why the patient is ill?
Pirate88179
Quote from: joel321 on April 25, 2015, 02:22:04 AM
The patient is probably ill from reading your inane posts, ha ha.
The cure?  I would tell him to stop reading your posts.  Case solved.
Bill
joel321
QuoteThe patient is probably ill from reading your inane posts, ha ha.
Sooo many opportunities for you to show proof anf yet soooo many let downs. You have ADD, you like to change topic over and over again sir. Hmmm three paragraphs ago we where talking about over-clocking a CPU which I asked many questions to see that MAYBE YOU KNOW MORE THAN I DO, and I get this pathetic reply. = Pathetic brain thinking.
Yet again your brain way of thinking capabilities disappoint! = entertainment only! Hey clown, why don't you cup your hand, fart in it, and transfer the fart to your nose and then smell it for all to LOL? Because There is no much greater brain power to get from your head lol. I'm afraid you have a disease it's called living-in-lala-land disease. You seem to say that you know something, when you are really PAINFULLY shows like an open wound that you are mistakenly very very wrong. Lol  Pour alcohol on  those wounds bill. You are wounded all over the skin.
Remembers decades ago when I asked you how you overclocked a CPU? NEVER gave an answer!!! lol Now you have no LOGICAL AUTHORITY to talk about further logistics if you skipped that = PURE entertainment from now on!
Lets all hear it for bill, the vaccinations sub-forum clown. Watch him eat fire! Watch him JB weld his diabetic heart valves.
Pirate88179
Quote from: joel321 on April 25, 2015, 04:24:02 AM
I use ClockGen.  It is free and it works well.  I am not going to try to tell you how to o'clock your CPU because if you don't know what you are doing...your computer will fry.  You asked how I do it?  That is how.  Simple, easy and fast.
Please do not try this at home.  While ClockGen does not recommend JB Weld specifically, I can tell you that after trying several other epoxies, JB Weld works the best.  But, use whatever you think you need to at your own risk.
Bill
