TinMan Generator Research Moderated Topic
Started by gotoluc, July 19, 2015, 10:49:03 PM
tinman
Quote from: picowatt on July 23, 2015, 11:04:10 AM
Tinman,
So, basically, you would suggest something along the lines of the images Grum posted?
Would you suggest a fairly loose or tight fit of the PM within the bored hole (particularly with consideration of PM's flux path)?
Would you suggest using something on the backside of the PM to close the path to the frame?
As I stated in response to Grum's post, I would think that the bulk of the magnet's flux path would be more so "kept" within the material surrounding the bored hole.
I see you also have those screw shank end mills...
PW
If i was to do something like that,i would probably place the magnet inside a protective casing-like PVC pipe. Then a way to !monitor! that magnet and it's field to make sure everything is ok.
tinman
a.king21
Quote from: Grumage on July 23, 2015, 03:23:48 PM
Dear Brad and all.
No PM's yet but possible forward progress??
https://www.youtube.com/watch?v=4pdvvN8jcfA
Comments/observations most welcome.
Cheers Grum.
The only one qualified to comment is Tinman.
Jimboot
Quote from: tinman on July 23, 2015, 07:31:10 PM
An interesting video. Maybe helpful toward the SS version?.
https://www.youtube.com/watch?v=BsN2sr3U0PY
Good observation for the tuning. Just one stator coil? Not shorting the other coil? Probes across the gen coil?
Grum
tinman
Quote from: Jimboot on July 23, 2015, 10:07:57 PM
Grum
Oops
Wrong video. Dont know how that happened, but I will post the correct one tonight.
