TheCell
Hello Yuri,
I replicated the device like shown in your diagram:
http://wyst.at.ua/_fr/0/0232461.jpg
with one exception: the primary has no tapping , so the lamp is allways connected parallel to the primary.
The trafo with lamp connected consumes about 90 real Watts, the Lamp consumes 75 Watts itself.
The trafo alone also 15 real watts power factor allways 1.
It does not matter which wire of the primary is connected to the thick wire, the values are allways the same.
Please help.
Yuri_L
Quote from: TheCell on August 01, 2015, 02:03:55 PM
Hi,
I faced with a similar situation at the beginning of my research.
I have some question to You.
1) How much consumes trafo without the shorted loop?
2) What is the current value in idling mode of trafo (without the shorted loop)?
3) What is the power factor in idling mode of trafo  (without the shorted loop)?
4) What is the value of the core area (in cm2)?
5) What is the current value in the shorted loop ?
6) How many turns are in pimary coil?
7) Where is placed the shorted loop on the core?
All these factors are essential.
At first You should get a "roaring" transformer without a load (but with a shorted loop).
Best regards.
Void
Hi Yuri. Can you please indicate where are you connecting your load for you last diagram?
I have tried this configuration and it draws about 20W in to the primary winding to
get about 75A on the single turn secondary. Where are you connecting the load
in your configuration? From the hot phase ('+') to the neutral? I am using a 600VA
power transformer toroid.
All the best...
Yuri_L
Quote from: Void on August 02, 2015, 01:18:11 AM
Yes.
But You shuld answer all above my questions too.
From 600Watt's trafo You can get 1.2 kWatt active pover.
leo48
Please The Cell
I have problems opening the file DSC00304.zip
Thank you  ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
