Paul-R
Quote from: Merg on October 21, 2015, 10:15:55 AM
Unbalanced Chan Wheel showing the Milkovic 2SO effect
https://www.youtube.com/watch?v=FolD_R32Eqw
This seems to be a mechanical tank circuit and needs to be tuned for resonance.
tagor
very good !
there is no output energy
and the wheel stops after a few seconds ...
so where is the "12 times more output than input" ?
ltseung888
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442470/#msg442470
(reply 2943)
For the bright student, the teacher only needs to say once.  For the lowest grade students, I shall say one more (last) time.
1.  Mass m1 is lifted only when the Centrifugal Force Fc + m2*g is higher than m1*g.
2.  During the lifting, the amplitude of swing does not decrease.
3.  The energy required does not come from the pendulum.  The. only other source is gravity.
4.  When m1 is raised to a high h, the potential energy gained is m1*g*h.  This lead-out energy is available to do work.
5.  The pendulum bob swings higher.  The velocity gets lower  The Centrifugal Force decreases.  The Force m1*g is again greater than m2*g + Fc.  The mass m1 falls back to ground.  The original position or state is repeated.
6.  The energy to return the pendulum system to the original position is m2*g*h.  This energy comes from the lead-out energy mentioned in 4.
7.  The difference (m1-m2)*g*h is used to produce the loud bang noise in the original Milkovic.  In the later Milkovic, that energy is used to pump water.
8.  That amount of energy (m1-m2)*g*h is relatively small because the period of the pendulum is fixed.
9.  The obvious improvement is to replace the pendulum by an Unbalanced Wheel.  The amount of gravitational energy can be increased hundred or thousand times because of the much higher rotational speed.
10.  The QMOGENs get it right.  The Motor is used to increase the rotational speed.  The Centrifugal Force varies as the square of the angular velocity.  Thus increasing the rotational speed leads out much more gravitational energy.
11.  The Tsinghua University Energy Multiplier is effectively many Unbalanced Wheels joined together to form Unbalanced Cylinders.  Thus it can lead-out much more gravitational energy.
This is the last time I answer this lead-out energy question.  If the student does not understand, too bad.  Let them ask help from the bright ones.
My focus is now in understanding and designing the UFO.
Lawrence Tseung
http://overunity.com/15077/ufo-propu-engine-closed-loop/msg454951/#msg454951
ltseung888
http://overunity.com/15077/ufo-propu-engine-closed-loop/new/#new
The two important aspects of UFO propulsion are:
1.  Varying circular motion produces changing centrifugal force.  The difference in centrifugal force provides the net thrust in the appropriate direction.  Multiple UFO engines allow hovering, sharp turns, going into outer space etc.
2.  Leading out of energy from the surrounding.  One form of energy is the gravitational energy that is available anywhere in space.  A horizontally pulsed pendulum will increase the tension of the string.  The vertical component of the tension will raise the pendulum bob and thus lead-out or bring-in gravitational energy.  The Milkovic two stage pendulum uses the pendulum swing to raise the weight to bring-in gravitational energy.  When the pendulum swings, the largest downward force is produced when the pendulum bob is at the lowest position - highest centrifugal force.  The weight is lifted at this point with no loss of momentum of the swing.
If gravitational energy can be lead-out or brought-in, magnetic or electromagnetic energy can be brought-in via magnetic pendulums in magnetic fields.  Electromagnets orientate the tiny magnets (dipoles) of the iron core to produce suddenly large magnetic fields.  A pulsing DC current acts similar to pulsing a pendulum.  Magnetic or electromagnetic energy is brought-in.  The brought-in energy is then replenished by the surrounding electromagnetic energy that is always available.
Both gravitational and electromagnetic energy are available in space.  Some positions carry more.  This is one possible scientific explanation of the propulsion of the UFO engine...
Both China and USA have developed UFOs...
