Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1015 Guests are viewing this topic.
Tomtech29
Quote from: NickZ on October 28, 2015, 01:43:29 PM
  Hoppy:
   Check the edit on my last post.
so far I have seen a drop in power consumption when it is running HV. but at the expense of other sources!
the answer is simple there is no person to prove it because none of us have not yet done.
Hoppy
Quote from: T-1000 on October 28, 2015, 01:52:29 PM
Nick,
The situations I am referring can be easily checked. With your grenade setup and series resonance instead of Tesla coil you can do little test with the discharge from flyback. Just do it on the coax cable which is terminated in copper tube with braid on the beginning and coax mid cable connected to the end.
Then bring the copper tube near grenade coil running and see what influence you get on the input and the output of power readings.
P.S. the phone spell checker sucks on electronic terms... :)
With respect the effect you have described cannot be easily checked. It will be necessary for you to firstly detail exactly how your DUT is constructed and setup and secondly to detail your power measuring setup, including measuring devices used. This will be best done using a new thread, as I'm sure that both TK and Verpies will want to be be participants.
Tomtech29
T-1000
a good shot but I have so much that he is the image and AD conversion so you can see exactly detail lol.
T-1000
Quote from: Hoppy on October 28, 2015, 02:13:52 PM
It just needs doing on your table like it was done in the past:
https://www.youtube.com/watch?v=qmirRN3O6Ko
https://www.youtube.com/watch?v=2xWZe6j5cPE
https://www.youtube.com/watch?v=7jtjgAwXqGg
Just bring HV discharge from small capacitor to your grenade coil and see what do you get. This stuff is highly experimental and is also shotgun approach. For full effect the Dally circuit with nanosecond pulses on the right time and position can be referred. The Tesla coil is used there for the same function just as higher voltage source (5kV+ spikes should be enough).
John.K1
Out of Topic- I just visited  Steorn's Live Webinar about their Cube. It produce funny 0.4W - charging the Lithium battery pack :)  Will cost probably around €200 :)
Back to topic - Romanov shows how mixing of two frequencies immediately charge the capacitor. Just need a "right waves - Правильные волны" :
https://www.youtube.com/watch?v=uRJx7Nh-Ols
One signal has around 15V & 157KHz , other signal -5V short impulse 20% 7,8 Khz .
