Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
@ Bob
Thank you for the source.  I think that everyone has already ordered their wire, but this will be good to have, if and when anyone should need more.
Do we just wind the primaries CCW, evenly spaced, if winding 6, over that last layer of tape, where your build left off?  Wax on the primaries and then tape over these again, to finish?  Or is there some other step?
Thank you Bob, we appreciate you and your time very much.
@ Mark
Welcome back, my friend.  You and your insight have been missed.  Now that everyones cores are arriving, things should get a bit more lively around here I hope.
Warm regards to All,
Bruce
Thaelin
Hi Bob B.
   I was just online trying to get the necessary wire and ran into a problem with the #16. Seems no one supplies it. I can get 18 and 20 real easy but 16 is multistrand. How much trouble will the 18 cause? Surpluss has none either.
thaelin
Bob Boyce
Quote from: Thaelin on August 29, 2007, 05:47:41 PM
Hi Bob B.
thaelin
Yes, you can use 18 guage. It will change the operating parameters a bit. Where are you located? I may be able to help you to find the 16 guage wire in solid.
Bob
Thaelin
Hi Bob:
   I reside in Portland Ore. area. Looking for 200ft of each. Thanks a bunch.
thaelin
Bob Boyce
Quote from: Thaelin on August 30, 2007, 03:35:42 AM
Hi Bob:
thaelin
@thaelin
What other size are you needing besides the 16 guage? I know of several places that have lots of the PTFE insulated 20 guage silver plated solid copper that is used for the primaries. ApexJr has a lot of that size, as does Skycraft Surplus in FL. Also can be found on eBay, quite common, and quite inexpensive as compared to buying new. 18 guage is also very easy to find, and if you are doing this as an energy experiment, 18 guage works just fine. The 16 guage was chosen for a particular application (the hydroxy gas application) not related to this energy only use.
I am waiting for another spool of the PTFE insulated 16 guage silver plated solid copper to be shipped out today from ApexJr in CA. I guess I must have picked up the last of what Steve had available, as he has said many people have called since I posted the information. I had arranged to get that spool of wire so that it can be divided up amongst some replicators I know that were short on funds to buy for themselves. I do know it is also still available from other sources, but at a premium that I personally cannot afford.
All I do to find this wire at the surplus prices is call around to surplus vendors and ask them to go check and see if they happen to have any full or partial spools hiding in their inventory. Most have had some and not even known about it! Steve didn't know he had a couple of spools until he actually started digging around and looking for it. Sometimes I find partial spools with a few hundred feet on them, and the prices are usually 1/3rd, or less, of the new price.
Bob
