TinMan Generator Research Moderated Topic
Started by gotoluc, July 19, 2015, 10:49:03 PM
gotoluc
gyulasun
Quote from: tinman on September 11, 2015, 07:19:33 AM
It hasnt died-it's just not here.
Some things are best hidden in plain sight.
Anyone know when the next PMBO is?
Hi Brad,
I just checked the rwgresearch and iaec forums and no trace of PMBO for 2015 as yet.
I wonder What you think you do if it will not be organised.    ::)
Gyula
tinman
Quote from: gotoluc on November 14, 2015, 02:53:51 AM
Getting closer, I think I just need to make the shorting circuit.
https://www.youtube.com/watch?v=hRoL9-j0k8U
Luc
It is good to see that some one has the determination to stick with it,and keep going until they start to see the end results getting nearer.
How much power is required to light that bulb to that brightness Luc?.
And how is it that when a load like this is placed on the generating coil not only reduces the power in,but also increases the RPM ?. Study the workings closely-the timing-the magnetic fields. You have an approaching magnetic field to a generating coil on the stater-->why is no CEMF(counter electromagnetic force) produced by the generating coil?.
Then think about what would make the motoring action stronger. What would the electromagnet stator section act most against,and how could you switch that force (change the forces direction) in synchronization with each rotor field change. You just need to bias the transformer like the guy dose in the video below,but where you have rotation,and he dose not.
https://www.youtube.com/watch?v=2kosQIrDCWM
tinman
Quote from: gyulasun on November 14, 2015, 05:04:58 AM
Hi Brad,
Gyula
I would say i dont think there is going to be one this year.
Perhaps Russ is too busy?.
gotoluc
Quote from: tinman on November 14, 2015, 05:30:42 AM
No power is required
In this modified universal motor configuration, when one uses the stator coils only as generator coils and only allows the induced rotor coil current pulses to go in one (correct) direction, it will assist the rotor and at not cost of current to the rotor coil input.
Modifications need to be made to the rotor commutator, brushes and timing to get this effect.
Best for me not to explain this yet as I've got a lot of things going on at this time. It will all come together soon.
Thanks for sharing that ;)
Luc
