Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
Nink
Quote from: Atommix93rdAtom1 on December 09, 2015, 08:46:49 PM
This is where I am ! I have 9 different free energy systems and all paid for by a small UK government loan ! My role is to deploy these generators to my clients !
1 , Zero point magnetic generator and no I don't spin magnets ! But it surly does some strange things as when it speeds up the current heads down to zero amps .
2 , Unified field oscillator , this one is a close replica of the NASA secret UFO ! And I do mean unified field oscillator as it has the ability to unifies all states of energy and can also bridge the dimensions by what I see as the cosmic octave . To understand it you need to know what the numerological constant of the 9 is and how it works with space time.
3 An infinity generator with no moving parts no high voltage and works in a pure DC current with electron propagation as its feed and main energy gain .
4 Magnetic vacuum high powered one way oscillator with no depletion and over a tone of pressure per inch in the rotation but not cheep to make .
5 A special high resistance coil wound on a 2.2 inch plastic pipe and confirms space time curvature at 2.2 degrees imperial and not metric ! And this can super phase with the spin of photons that are also confirmed by this equipment to have the same vector of angular spin as space time curvature.
6 Zero point water splitter using charged water .
7 Ambient radiant inducting coil with strange static sparks 2 inch from its contact terminals when connected to a small 500 watt universal motor .
8 A powerful negatively charged coil generating system .
9 A real monopole electro magnetic field generator and will produce monopole magnets .
Could you choose one and post a video of it generating power and provide some verifiable test results. Could you also shrink your diagrams and not leave 50 blank lines at the end of your posts.
Quote from: ramset on December 10, 2015, 08:35:06 AM
maybe your room full of amateur Physicists could figure out how to post a Doc here and not make the readers have to put their running shoes on to read the whole page ?
BTW
93
here are some other fellows you can "help".
http://www.energeticforum.com/renewable-energy/20331-enlightened-magnetism-full-proof-ken-wheelers-theories.html
It's because of those HUGE IMAGES that "93" posted.
ONCE AGAIN, people, posted images should be 1024 pixels wide OR LESS, otherwise what ramset is complaining about will happen, as you can see.
800 pixels wide is generally fine. If you need to show some great detail, crop it out and post the cropped version.
There are many image editing programs that you can use to resize images to the correct pixel dimensions.
ramset
Tinsel
Yes the Quote [miss quote now that I read it again ] came from 93's dizzying post..
and I am well aware his Doc grew the page, and was attempting to make him aware.
93
A tiny had full of amateur physicists have some how created a magnetic field for every thing hahahaha nuts ........
ps
thanks for reposting the forum protocol for Doc sizing
@Tinsel
end quote.
Chet
PPS
and thankfully we have turned the Page
:o
Thanks Grandma
minnie
  Cycle,thanks for answering my question. Kelly refers to "idiot Einstein" and
"Quantum bullshit". These are the couple of things that got me interested in
this topic.
    I hadn't given any time to this subject 'til Kelly cropped up. I have now got a
bit of an idea as to current thinking but haven't got the first clue as to the
scenario that Kelly is painting.
  Anyways thanks again for your input and I'll keep on reading what everyone
has to offer and hopefully one day I'll be able to draw a conclusion,
       John.
CycleGuy
Quote from: Atommix93rdAtom1 on December 10, 2015, 07:54:00 AM
That's a bit confusing the vortex is not in our time frame and the observations of fast and slow time are a bit off putting ! Thus far time dilation is produced by mass not a magnetic field
Stressing the QVZPE field affects time. Think about how generators work. Why does the spinning of the generator force electrons out over the wire? It's not mass. It's relativistic space-time compression mediated through magnetism (denoted as Larmor radiation mediated via virtual photons, a component of the QVZPE field), thus perceived charge compression, thus current.
Now think about why mass affects space-time. Might it have something to do with QVZPE field density? You bet it does.
Now think about why planets with different gravity will experience time passage at different rates, and why satellites experience a faster time than clocks on Earth, despite their relatively faster speed negating some of that gravitational time-shift.
Which is yet another method of destroying Mr. Wheeler's "instantaneous action at a distance" contention... if he were able to send information from Earth to Mars, via his "instantaneous action at a distance", and let's say it's sent in a time frame that equates to 3pm Earth-time... since the lower gravity (and hence the lower QVZPE field density) of Mars means that time will pass faster there than here, Mars will have already been past the same time frame as when he sent the information, so conceivably they'd receive it before he sent it... meaning causality was broken. Ergo, "instantaneous action at a distance" cannot exist.
.. Also fields and particles are the same so why say that particles don't exist and only fields do ?
I certainly never denied the existence of particles. That's Mr. Wheeler doing that.
We know the electron is a particle... it has rest mass and it rejects QVZPE field modes longer than the Compton radius (as all matter rejects QVZPE field modes longer than its radius):
http://vixra.org/pdf/1203.0033v1.pdf
"Proton and electron mass derived as the vacuum energy displaced by a Casimir cavity"
Two of the great mysteries of physics are the origin of mass and the mysterious mass ratio between the proton and electron of ~1836. In this paper it is shown that the mass-energy of the proton is equivalent to the vacuum energy excluded by a spherical Casimir cavity with an average radius equal to the charge radius of a proton. Likewise the electron mass is shown to be equivalent to the vacuum energy excluded by a spherical shell with an average diameter equal to the Compton wavelength of the electron. The ratio ~1836 is derived as a natural consequence of the vacuum energy exclusion.
We also know the electron has wave-like properties... because it is so small and light that the QVZPE field modes it excludes impinge upon it... so what we're seeing when we do the double-slit experiment with electrons isn't the electron being a wave, it's the electron being impinged upon by QVZPE field mode waves (the QVZPE field being comprised of electromagnetic waves of all frequencies from DC to the Planck frequency). It's sort of like that carnival game Plinko, you put a disc in at the top, it bounces off pegs as it goes down, you get a prize if it lands in a certain spot... now substitute the electron for the disc, and the QVZPE field modes impinging upon the electron for the pegs. We're seeing the anisotropy of the QVZPE field. Doing the double-slit experiment firing the electrons through a Casimir cavity designed to damp the most prevalent impinging QVZPE field modes should prove this out... in so doing, the researcher will find the electron's behavior much more particle-like (rather than wave-like) than it usually is when doing such an experiment. Of course, there's no way to block all QVZPE field modes (mainly because the metal of the cavity is transparent to higher-frequency modes), but damping some of them should give researchers the clue they need to resolve the wave-particle duality issue.
There is to much hyper junk physics on the attempts to change the current and excepted view that still stands in the cosmological principle !  Einstein is correct as re time and gravity with space craft now launched to observe gravity waves and also curvature in the fabric has already been confirmed.
Other things to consider ! Millions of people time travel in there dreams this is a result of gravity waves nothing to do with magnetics ! I strongly suggest the theoretical magnetic vortex should stand only as a theory until it is observed beyond that of a black hole and that has now been observed.
The idea of slow and fast time between two fields or at the inner or outer construct of a magnetic filed is impossible around a magnet but not impossible for a black hole ! The way I view all this is if I can not personally Isolate a magnetic vortex with out a magnetic than it does not exist ...  All this hyper theory can sound interesting but that is all it is !
I didn't say it was a large effect... but then the relativistic effects at work in a conventional generator aren't that large, either. For instance, if you ran a generator such that it had an outer perimeter velocity of its rotor of 1500 MPH for one hour, it would actually experience 0.99999999999749848054 hours. That 0.00000000900576 second time difference over the course of an hour is what is responsible for the generation of the electricity due to relativistic space-time compression and thus charge compression. And that's a lot of space-time compression as compared to the electrical grid generators.
A very basic video addressing the topic:
https://youtu.be/1TKSfAkWWN0
The constant attacks on relativity is only an attempt to beat the master at his own game without the master being able to reply ! And to confirm a better understanding its a good idea to speak to the mast Einstein himself and Max plank Maxwell ect ect but you may fill that is impossible but I will not agree ...
I'm not trying to beat the masters at their own game, I'm attempting to understand what they understood. Perhaps by understanding what they understood in light of modern technology, we might be able to conceive of something new that could not have existed in their time.
This whole Idea of a magnetic form of gravity is completely bonkers ! The fact that NASA have studied some tiny effect on the fabric of space time with powerful magnetic fields is one thing but they require the impossible anti matter generator that is also bonkers and just hype physics .... I have had the good experience of being within 500 ft of 6 UFOS and not magnetic fields were being used !
Gravity Probe B confirmed gravitoelectromagnetism.
https://en.wikipedia.org/wiki/Gravitoelectromagnetism
I suggest you study the subject of stress-energy tensor.
https://en.wikipedia.org/wiki/Stress%E2%80%93energy_tensor
The stress–energy tensor (sometimes stress–energy–momentum tensor or energy–momentum tensor) is a tensor quantity in physics that describes the density and flux of energy and momentum in spacetime, generalizing the stress tensor of Newtonian physics. It is an attribute of matter, radiation, and non-gravitational force fields. The stress–energy tensor is the source of the gravitational field in the Einstein field equations of general relativity, just as mass density is the source of such a field in Newtonian gravity.
The stress-energy tensor concept is what leads to the conclusion that energy converted from mass in stars is entropying, becoming part of the QVZPE field, and thus increasing QVZPE field radiation pressure. The universe has only two options... either expand or concretize mass... to relieve that field radiation pressure. Right now, it expands because that's the most energetically conservative thing to do. Earlier in the universe's existence, it was obviously more energetically conservative to concretize mass, accounting for the 1 billionth of all that energy expulsed from the Big Bang being converted to the mass we have today.
So that accounts for universal expansion... it also happens to account for universal expansion at faster than the speed of light. The QVZPE field being a magnetohydrodynamic fluid, a plasma, electromagnetic waves (of which the QVPZE field is comprised) can travel faster than c if the frequency is higher than the plasma frequency, as I outlined in another post.
So the "dark energy" all the physicists were looking for was right in front of their faces the whole time they were denying that the QVZPE field (ie: the "aether") existed.
Atoms and there particles are real ! So what if there fields mass has to be something but there fields are focused to there core nuclei where the quarks require them to keep there position in the proton ! So the fields are already taken up and if it was any different than all material would be strongly magnetic .. Gravity is different as its curvature sets up the force of attraction but that increase in speed is quantised suggesting that waves are included ! These waves are not magnetic or have any EMF construct so the fabric is a condition and construct of the plank constant or as we like to call it the zero point field..
Max plank was more than just a master of physics he had a lot of faith in the supernatural and came to the conclusion that the universe or at least a galaxy is a conscious being and very much like a matrix or as many now call it a brain ! This is very important as we have 200 billion neurons and our galaxy has 200 billion stars ! We consider that the galaxy can not build anything more complex than its self !
This may be strange to you ? But we see that every particle atom field is in a perfected position in the space time continuum and to that we also conclude that numerological constant of the 9 as the major influence by which all is constructed .. As re magnetic fields say that of a magnetic there must be a polarised form of charge that keeps them as a stable construct and either end is also a set field formed by there dynamic harmonic response when first charged . Meaning they resonate at the charge frequency but in two harmonics say NORTH as C and SOUTH as F ...  C#  D   D#  E   F  And is a fifth note in the scale between N and S in other word they are harmonics composed from there point of charge ....
We have to include dimensions if we want to isolate the polarised charge as we can not directly measure them in our dimension ! There is no magnetic vortex beyond the surface of a star or around the event horizon of a black hole ! What you will see is a vacuum and some entropy for say NEO magnets ! The spirals that are found in geometry are in fact a construct of there harmonics in the chromatic scale and only particles like ions will flow to these patterns and not MF ........
The difficult part for you to one day except is that the galaxy it in it self a being of intelligence and has total control of all its parts and that does not require for the parts to all be fields ! A ghost was once given a present as a simple toy in a box and when the researcher returned the toy had been removed from the box but the box still had not been opened .... Beings have been seen to walk out and into mirrors , wooden tables levitating and people to all with no magnetic fields or vortexes !
Christ feed 5000 people with 5 bread roles and 2 fish and walked on water also turned water to wine and brought a dead man back to life all with out magnets or vortexes and Christ was not the only one who could do these things ! A magnetic vortex  would create a worm hole and there are no worm holes !
So particles are reality ! We call them particles you call them fields same thing ! And all this with out entanglement or propagation what they are looking for does not exist beyond that of a simple vacuum ......
Please consider the numerological constant and the cosmic octave as the back bone for the grand unified field as with out it nothing would exist ! A tiny had full of amateur physicists have some how created a magnetic field for every thing hahahaha nuts ........ Time is independent and requires no magnetic field ! What's wrong with nothing why does nothing have to be a magnetic field ? Entanglement requires nothing no time or space or some stupid string or magnetic field ! Its consciousness beyond the mechanical ! Than we enter the supernatural and ghosts are not magnets yet magnets can open up dimensional holes not worm holes ...
In the fifth dimension there is no time or space ! So what does that tel you about a magnetic vortex ? .... A hole can open and close without a vortex just in the same way as a window or a door can !
I see spirals particles atoms and geometry time and space in our 4 dimensional galaxy but no magnetic vortex is required there for they don't exist beyond the surface of the sun or a black hole !!! Or please provide a man made version !!!
I don't know about all that spirituality stuff. I'm attempting to understand it from a more mechanical point of view.
