Joule Thief 101
Started by resonanceman, November 22, 2009, 10:18:06 PM
picowatt
Quote from: EMJunkie on April 11, 2016, 06:03:28 AM
PW - Youre still Wrong, and still wont admit to it.
You see, Brads circuit was never in question. Its TKs explanation of it.
You stated that TK was wrong and that the correct answer was 180 degrees, so at least in your mind, Tinman's circuit was indeed "in question".  It's good to see that you have changed your position and now agree that TK correctly chose the 90 degree capture.
As well, both TK and Tinman used Faraday's law to predict that the induced voltage would be at a minimum when the rate of change of the magnetic flux was also at a minimum.
Using the 90 degree scope capture, both of them indicated where the induced voltage was at a minimum, and as well, where the rate of change of the magnetic flux was also at a minimum, and how those points in time were in alignment.
Surely you agree that Faraday's law predicts that the induced voltage will be at its minimum when the rate of change of the magnetic field is also at its minimum...
EMJunkie
Quote from: TinselKoala on April 07, 2016, 07:07:29 PM
Brad, your scope shot shows the expected 90 degree phase difference as predicted by Faraday's Law:
You see, Faradays Law is entirely dependant on the very values that TK says that Faradays Law Predicts.
See, math shows you and TK to be wrong:
Quote from: Faradays Law of Electromagnetic Induction
E.M.F = -N dϕB/dt
Where:
Quote from: http://www.colorado.edu/physics/phys1120/phys1120_sp08/notes/notes/Knight33_induction_lect.pdf
ϕ = BA Cos(θ)
is a change in ϕ in respect to time. So this quantity is a necessity, to accurately know, well before we can even calculate Faradays law.
This quantity (ϕ) is Design/System dependant, in other words, different Geometrys and Magnetic Fields will show a completely different result for ϕ!!!
This is completely independant of Faraday's law!!! Nothing to do, at all with Faraday's Law!!! Infact Faraday's Law is Governed by these factors!!!
The Only things that Faradays Law Predicts:
   1: The E.M.F
   2: The Sign of the E.M.F
As stated many hundreds of times now, the Sign is Anti Phase. 180 Degrees out of phase from the Source.
Specifically!
So my Flowery Science fiend, you are wrong, dead wrong, and to stubborn to admit!
Brads Circuit is completely outside of these facts and not the topic of this debate. It is entirely related to the description TK presented of how the Circuit was working as referenced above.
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on April 11, 2016, 06:29:49 AM
So you don't believe that Faraday's law predicts that the induced voltage will be at a minimum
when the rate of change of the magnetic field is also at a minimum?
EMJunkie
Lets look at another simple example - Shall we?
Lets take a Permanent Magnet, 200 Gauss, and spin it up on a rotor in Germany.
Lets take a Stator in Sweden, with 500 turns on it!
Now the Time Rate of Change of the Flux calculated is dϕB/dt where ϕB is calculated from ϕ = BA COS(θ) where θ = 200 Gauss at 3 degrees.
Now, according to YOU and TK, the gurus you are:
But we know for definate sure that the 500 turns will have NO E.M.F
Does this sound like a logical plan that you and TK are taking?
Are you still Right? Of course not, no you are not right at all.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: picowatt on April 11, 2016, 06:38:13 AM
I believe in you PW, your fairy tale science is aweinspiring!!!
   Chris Sykes
       hyiq.org
