Mechanical resonance (Projects unlike forums hacks Tinman and Magluvin)
Started by ARMCORTEX, April 20, 2016, 02:59:16 PM
DR.WHO
Here is a wave
wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
Here is the same wave as a stream of particles
Here is a straight line of force
______________________________________________________________________________________________________________________
To make this easy to understand above we see a EMF wave and it is interchanging between being a wave a particle and a line of force and you may wish to call it a magnetic line and that is ok but what else is this line of force ?
We know that space time is the fabric of all that is and if we want to exit or enter the universe we will need to either cross over a line of force or entre or exit through a door of some kind . This is also true for particles including anti mater !
The reality that anti mater exists is confirmed by the presence of back ground radiation but as I like to keep things simple I just want to except this as a fact and stick to why this line of force is important in the resonance field for gravity !
A wave is also a particle but it can become a line of force like a magnetic field line and this line can create a vacuum in space time at speeds above the speed of light because it has no mass ! When you open a door the mass of the door has been moved aside !
Look again at the wave and study what happens when it becomes a line and we see that all the peaks in the wave have flattened and if we recreate the wave again from the same line of force  the space between the peaks is compressed !
All mass is in a fluctuation field of this kind from wave to particle to line of force ! And when two objects say two apples are close together in deep space they are attracted to each other by resonance and this forms the bond of gravity known as the weak force . SIMPLE !
Anti mater must exist or nothing would exist not even time ! So the wave the particle the line of force are a condition set up that permits anti matter to be in harmonic balance and this anti mater is fluctuating between dimensional positions on either side of the line ! This movement sets of the resonance creating all mass to be stable as a constant of energy !
If I open a door fast it creates a vacuum and any object on the inside of the door will want to move towards the the opening of the door ! This is gravity and its effect is a constant equal to the constant of the fluctuation of  anti mater !
This is also a very powerful free energy constant ! And I will show you how to tap into it ! But understand resonance was set up at the very beginning of the creation of this dimension and its never going to stop until its resonance meets an equal amount of mass that is moving at speed towards our universe .
This is now confirmed ! ...............................................................FACT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SORRY .... But it will all end very soon ! So stop fighting learn and build share and give me all your money ahhahaah lol x
memoryman
 DR.WHO should call himself Mr.What. If you are sloppy in spelling and grammar, you are likely sloppy in other aspects of life as well, including but not limited to: relationships, your work/hobbies, dress, physics, hygiene.
Consider the following: work is the result of energy flow. Energy is neither gained nor lost while work is done, unless it is converted to/from mass {1st law of thermodynamics (LoT1)} Now also consider that LoT2 is not an absolute law in the sense that LoT1 is (it's a statistical law), and let your imagination go.
Temporal Visitor
Quote from: ARMCORTEX on April 30, 2016, 08:28:12 PM
And you Temporal, are a fraudster.
Wrong!
I remember you were willing to accept 3000$ from me for a device with was 1 meter square supposedly.
Wrong again! You asked how much it cost to build and I answered you with a guess on what I spent. In fact you said you were dead broke and couldn't afford anything going on to talk some rather weird thoughts.
You will not find me defrauding people.
You are the last person that should speak.
Me I am the honorable ronin of overunity if anything, I have earned my bragging rights more than once.
I will repeat, Topsolid 7, Spaceclaim, microcontrollers, makes me the biggest maker that posted in this thread.
My superior skills in Topsolid 7, Spaceclaim, gives me the edge, sorry.
Like I wrote before, you need help. You believe your own lies.
DR.WHO
Memory man get to grips with your reflection ! You make judgement of my appearance ? stop the little boy routine !  The level of precision I my work IF i LET YOU SEE IT ? is far to complex for your little head hahah
I like simple easy and a slow walk up to the complexity and tighten my rope when I fill a need for it but a bit of slack is often a good thing and you seem to be a loft with your ability to spell ? mmmmmm interesting this is about physics and quantum mechanics are you sure your able to cope with that ? Try a story telling web site or read harry potter .. hahahah
I am a master of the field as we say and a few quantum short of good eye sight but now and then I wear my specks hahaha ! No force is permitted to exist as a confined ideology created as error by them that had not considered the multi verse . If say I was to create a one way moment of thrust in one direction from a standing point why is it that you keep thinking that it will generate an equal amount of reverse thrust . ? The so called opposing force is simply defeated when two apples in deep space attract each other.
Let say that one apple would just vanish at given moments in time and this fluctuation is a constant that is invisible like anti mater ! So we have only one apple that we can see and its anti self is on the other side of the door . Its becomes obvious that force is there for one way directional as is gravity so its very simple to re create that effect with a box that is free to thrust in a one way direction with out an exhaust ..
HAHAHAHAH ITS IMPOSSIBLE TO BEAT ME SIR ! I AM THE BEST THERE IS ON THIS SIDE OF THE BLACK HOLE ! And I do mean the one that is inside of the sun ...
You have to now let go of all your claims that any and all release of energy creates an opposing reaction or force ! Energy that is gravity does not display that and there for the claim is DEBUNKED by me ...
Dont try and tune my coil son I will do that in good time ...... check mate hahah
memoryman
