Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
Farmhand
I don't know what to say about this video below except that it is quite humorous and probably not far from the truth.
I think this video probably expresses what many people think. For best effect please watch it in it's entirety.  :)
https://www.youtube.com/watch?v=1g_f8LDSLlA
Another video with some interesting info from about 2:30 in the video.
https://www.youtube.com/watch?v=wY5VwHrLciE
gravityblock
Quote from: TinselKoala on May 01, 2016, 04:50:31 AM
Thank you for proving once again how idiotic your claims are !
Oh... I forgot to give you your ROFL !!! If you knew anything about aviation you'd know how silly your claims are.
Of course airplanes are affected by the Coriolis effect, but the magnitude of this effect is so small on the scale of aircraft landing/takeoff operations that it is virtually indetectable. Even the slightest crosswind component affects the aircraft more than the Coriolis effect. Try looking up artillery aiming, if you want an example where the CE affects practical outcomes and must be corrected for.
Now look up the Foucault pendulum experiment and explain why the big ones in the Deutches Museum in Munchen, in Paris, at the University of Chicago and elsewhere work as they do.
http://www.youtube.com/watch?v=ySBvh8XgyvA
Oh... I forgot... they are all fakes, aren't they.
Come on, tell us another one!
The Foucalt's Pendulum Debunked!  The Foucalt's pendulum makes more sense on a flat earth than a rotating earth.  Below is a quote by don Quixote on the youtube comments:
"Did you read Umberto Eco: Foucault pendulum? Even he appears to have problems with this: for one, the pendulum is not suspended freely, only as free as high precision engineering allows for; secondly, as you noted, those pendulums are augmented with magnetic, or electro-magnetic devices to maintain their oscillations. Those issues can obviously affect the behaviour we see, therefore falsify/corrupt data. Bim found out that when they put a Foucault pendulum in Antarctica they found it rotating against the expected direction and had to tweak it twice (few days of solid work) to make it match the predicated model.   I believe they mess with the balance actually. Indeed the star trail! I am tempted to look at the electro-magnetic field as per the toroid model controlling the firmament. or celestial bodies above, but other less known phenomena can be at work here for sure. Coriolis, as a certain predilection in the clouds movement, is not otherwise present in the ballistic trajectory as far as my experience attests - I have a vid on my channel called the rocket man.  I have subbed to you for a while now, love your graphics and obvious knowledge and intelligence and you are a fantastic communicator. Well done!"
A quote by, Dubno Val:
"yes from what i understand, the actual experiment is likely promoted and tailored to show what they need it to show. my point is, even that being said, the explanation they give us disproves itself. whether the experiment actually works or not, it doe NOT prove a globe and works better on the flat earth model."
Gravock
gravityblock
The well known Michelson-Morley experiment clearly shows no rotation of the earth!  I posted this earlier and there has been no attempts to refute it.
Gravock
tagor
Quote from: gravityblock on May 01, 2016, 05:56:00 AM
Gravock
this is absolutely false
are you very very sane ?
gravityblock
Quote from: tagor on May 01, 2016, 06:14:47 AM
If not, then we have a perpetual motion machine!  What's being used to maintain it's oscillations?  Explanations of the mechanics (snapshot below).
Gravock
