Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
Magluvin
One more and gotta go.
I did some shots of the bifi and the normal coil at 400us and 80 us for comparison.  First 2 are the bifi and the next 2 are the normal coil.
In both shorting tests the bifi seems to charge the cap faster and both coils demonstrate being able to charge the cap above 30v at nearly the same rate of rpm. The normal 1.65mh has more drag on the rotor it seems compared to the 27mh bifi. More controlled tests to determine better.
Mags
Magluvin
The bifi is 26awg series conected and the normal coil is 18awg.  About the same size but big difference in no of turns.
Mags
tysb3
Hi
There is my 2 cents for shorting generators coil.
I found that with one red switch was charging  over 150 volts only one capacitor, another was keeping less than 10 volts. Then I change turn direction and there  was charging another capacitor. Then I connect second red switch.  First switch was "on" on incoming magnet, another - out coming and both capacitors was charging.
Generator coil is on the core from MOT transformer about 800 turns, wire diameter is about 0.6-0.7 mm. Coils resistance is about 15 omhs.
For better Lorentz force compensation capacitors in each cycle need to be discharged.
tysb3
dieter
No I guess you were right:
-Lorentz force
-Lenz' Law
Basicly, without Lorentz force there were no electromagnets.
Only, in induction generators, unfortunately it opposes the mechanical motion of the inducting field (says Lenz)... normally ... harhar, but now kansas ain't what it used to be.
Looking good, keep up the good work.
