Keshe update
Started by markdansie, January 29, 2016, 08:29:38 AM
Qwert
For this kind of event, I guess the white house (certainly not W.H.) resident certainly would sacrifice his vacation. But... wait a minute: why not kremlin resident? He is obviously closer to and more friendly to Iranians. ;)
Dog-One
I do recall Mr. Keshe explicitly stating he knew Obama would not be there which was part of his strategy and why this weekend was picked to begin this tour across the country.
Later today or possibly tomorrow, we shall see how his strategy plays out.  I'll be very surprised if any of us see a full disclosure of how to build a Magrav unit ourselves.  We can hope I suppose.  I'll also be surprised if Douglas does not find himself incarcerated by the end of the day, depending upon how aggressively he approaches the Whitehouse.  I really can't say I agree with Mr. Keshe's plan.  Top down is simply not going to work.  If he truly wants to change the world, it will have to be bottom up.  He could easily document everything necessary to build a functioning Magrav and release it as a torrent file that would spread across the Internet in just a few hours.  There would be almost no stopping that short of a complete Internet blackout.
It's Mr. Keshe's backwards thinking that really makes me doubt what he says he has.
Anyway, here's the live stream if someone wants to follow their progress and report on any major events:
https://www.youtube.com/c/KeshefoundationOrg/live
kEhYo77
wattsup
Hmmmmmm.
@all
Well from my last post on this thread, I might windup eating that Quiche myself. A very good local friend that is in a small group working on the Magrav for several months now called me yesterday to say it is now producing a good 3000 watts of juiceroni. I asked if I can go and inspect the device in operation with proper measurements, scope, etc. He said the group s a little leery of having outsiders at this stage. I will push it with him to see if this is legit or not.
Spin Conveyance (SC) and the Magrav.
If the Magrav is indeed really producing electricity as shown in some new videos on the net, the cause which is now explained as a "plasma" event is most likely not the case. But SC could in very simple terms.
I have been discussing on and off about why our copper wire is the cause of our limitations to produce OU devices. Much of this is discussed at etherimpress.com under SC.
The main point is electricity is not a field and electron based phenomena. It is a physical copper nucleic phenomena where the physical spin or sway of copper nuclei is conveyed from one atom to the next without any "traveling" or "flow" of electrons. The magnet or energized coil is not an outgoing impress of a field but an inward impress of gravity. Copper nuclei respond to this gravity presence as a physical movement of spin or sway that gets conveyed down the wire as electricity. This simple construct of SC explains all our effects, including the infernal resistance in our wires which could be explained in detail on another thread.
The point is I have been poking at copper wire quality for a long while now. Mostly saying that if copper wire could be produced by extrusion in a flat form (not round) and when exiting in a molten form passes by a strong magnetic polarity on one of its sides before it cools off, those aligned copper atoms would produce OU devices. This because cancellation in a wire is based on the random orientation of the nuclei in our copper atoms.
It seems that the Keshe system of conditioning the copper coils after they are wound by simultaneously heating the non-insulated inner and outer coils red hot produce both an outer carbon coating that acts as an insulator between both inner and outer coils and between coil turns, plus, the great adder is the actual copper atoms being heating re-aligned their nuclei where a higher percentage of the nuclei are now aligned a more specific vector. This creates what? The same thing that energizing transforms a dead freshly made neomagnet mass to become a supper magnet. The neo magnet did not receive "electrons" or a "field". The only thing that can happen is a realignment of atomic nuclei because the exterior coating of atoms cannot be affected otherwise the mass will change in its physical form which it does not.
As the neo mass becomes a magnet where atomic nuclei are positioned in a naturally balanced vectorial mutual confinement, the nuclei can now make other nuclei spin or sway against EACH OTHER. It is this movement that creates the magnetic influence which is an increase in the internal gravity of the magnet. The magnet is not heavier, it just becomes a higher gravity force or presence. That is what copper nuclei respond to.
So if Keche is in fact real, then the only explanation is the mutual inner and outer coil atomic nuclei now act just like the interior of a magnet where the spin or sway can happen and is exchanged by mutual cause and effect just like a magnet. The only difference is the copper atoms are arranged in a linear conveyance where each end of the coils produce their final output conveyance we see as potential difference. The magnet is a closed topology where such conveyance cannot be imparted to the outside world save with action at a distance. The magnet passes the wire and the wire converts the physical passage into an internal spin conveyance of potential.
So under SC, the Keshe device as it is produced today is at such a fledgling stage that once we learn of the real atomic prowess of copper atom nuclei and once we learn how to make copper wire that is really physically oriented, like if you could actually use a 3D printer to make your copper coil atom by atom, the real power of the atom will be available in a ten cent device that will run a home.
So, again if Keshe is real, Spin Conveyance would have no problem explaining the process since I see Mr. Keshe is on a very right path of the device working but his "plasma" talk and attracting the "ether" energy is again stone age talk. SC explains it to a tee and this introduction of the Magrav falls just at the right time for SC to be better explained.
I have said it so many times, our copper wire is the same damn copper random crap we have been making for the last 100 years. While tech has advanced, we are still on step number one when it comes to atomic/nucleic/conductive atoms. The change is happening slowly as good things that last usually do.
wattsup
