THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Magluvin
Quote from: Sequental.9 on September 10, 2016, 07:47:45 PM
THE REAL TPU is programmed ! In the same way as the method as I have given you ! What pictures do you want ? A picture of a variac ? A video of a light bank ? It means nothing just pictures and a video ...
You have a chance to do something very important ! It's not a lot of time but I will add simple alternatives that require nothing more than just an off the shelf variac... But you can go much further than what is already well known.
Also so far I have made public some technology here so as to counter any claim of patent on it and If sometimes I post derivatives its to stop the dead meat of patients ......... Their are hundreds of them and not one on the market ! All the inventors just roll over on their patent hoping some idiot will invest millions on it...
That is never going to happen and if it does I will make sure it ends up in the bin with the rest of the crap in the patent office ! Am I a LEADER ? Yes, sir ! Why me ? I know more than truth I know what the future holds if you don't let go of your blind doubt and follow through.
When the mind is challenged by the unknown and reality is opened wider than ever before the world we live in begins to change and what we once new becomes only the seed and yet even a seed needs the right conditions to grow.
Your nickel wire is all you need to isolate the truth ! But I want to grow that truth right up to the point where the variac is a float 1 metre off the ground.
I am here doing the same thing as you but only a few steps further down the line and I have much faith in you MR VORTEX ! You need to find that faith and grow it, X, potently .....
There is no hurry ! Your fellow Americans only trust other Americans and they will trust you ! The fear as to what such findings will bring and one must conclude that soon men will come with other ideas and not all will have the living spirit in them like me.
It is impossible to challenge me I never compete ! ...
Please continue with the voltage results and then we go all the way up the ladder until you pull away the work bench and the variac just floats without dropping.
This is the freedom we WILL all have if you slowly climb the ladder ! Abundance and the keys to open the universe will be such a joy that humanity will completely forget alls its dysfunctions and hate and fear of one another.
WAR is so close and yet peace and the everlasting peace is even closer ! We must take this chance and make it so profound and as loud as a volcano or this world is doomed .................................................................. !!!!
Set it free Mr vortex ! Do it now as we still have a chance or it will be too damn late !
I am already in negotiations with manufacturers and I give my word any agreements will come to this post for a vote ! I am going to kick this planet right up the back side so god damn hard you had better be holding firm to the work bench ........
I ask you to all do the same !
Rember when aliens come to play with man's nuclear weapons and even land at a USA air base in England to count them . If you don't let go of the fear we will lose our right to rule our planet !
I now place firmly our world in your hand's Mr vortex .............. set it free ! ASAP ! Have faith and follow through !
S9
"THE REAL TPU is programmed ! In the same way as the method as I have given you ! What pictures do you want ? A picture of a variac ? A video of a light bank ? It means nothing just pictures and a video ..."
But pictures do mean something. Take 2 milk commercials on TV where one shows a cow in the field eating grass, then a slow pour into a glass from a glass pitcher. Then little Bobby drinks that milk.
But your milk commercial would be made up of rainbows, incomplete block diagrams of circuits without description.  Which commercial will sell more milk?
Your latest circuit with the 100ft distance between ground points. There is no indication of what we are doing with the cap bank and inverter. No indication of if the caps are precharged or if the 'missing' power source is still connected. No apparent recharging of the caps from the circuit, And if we need those 2 ground connections, then there are no flights to the moon any time soon. ::)
You present things in a terrible, way out of order manner. Just simply terrible.
Mags
Vortex1
Dear S9
OK so we'll forget about pictures.
I guess I should first re-run the temperature teats, as you seem to imply that it was important. Then I will move on to the 36 inch tabletop test, which I am setting up for now..
I have a very nice maple table that is precisely 36 inches top to bottom. Should the wires going to the ground be copper and is it better if the copper is oxidized (rusty brown)? Or should it be shiny new wire with no oxidation?
I'm assuming the nickel wire is for a load test, not the earth seeking prongs.
Should the variac face be pointing N, S, E, or W? or should it point to the moon?
What instruments did you use to measure the output and will it kill the effect if the instruments have stray capacitance to the mains? Should I use battery operated instruments? Does it matter?
A lot of questions, I know but I want to get it close to right on the first try.
I'm sure you've already been down this road so looking forward to helpful hints.
Kind Regards
Vortex1
Vortex1
Quote from: Sequental.9 on September 12, 2016, 03:14:53 PM
PLEASE INFORM NASA WE ARE READY !BUT IS MR VORTEX READY ? OR HAS HE BEEN VORTEXED ? VOLTS PLEASE !
S9
Mr. Vortex has been letting the test run but nothing to report. No activity, no voltage, no resonance, one full day now toroid sits on table with 36 inch wires to earth and meter at the tips but no voltage readings to report yet. I will probably have to try some of the tweaks you mentioned.
Regards, Mr Vortex
Vortex1
You asked:
QuotePlease, can you provide the correct coil length on the OD and ID of the variac ?  I am doing the harmonic position guide for it and I want to know what you will use to measure the tests with ?
Here are the full specs again:
QuotePrepared for Sequental.9          2 Sept 2016
Superior Electric Powerstat, Model 10 (Vortex1 Variac)
Weight: 725 Grams, 1.6 Lbs.
Dimensions:
Outside Diameter: 71.65mm  2.821 inches
Inside Diameter:   28.30mm  1.111 inches
Height:                  38.75mm  1.525 inches
Wall Thickness:     21.51mm   0.848 inches
Wire Thickness:  0.30mm   0.012 inches
Number of Turns = 563
Length of Wire = 250.82 feet (3009.78 inches)
Terminal #1 = Line Low Side and Output
Terminal # 2 = Line High Side (If only 120 V out required)
Terminal #3= Variable Output Slider (main output)
Terminal #4 = Line High Side (if extended voltage to 132 Vout is required).
Maximum Amps= 1.25
Inductance  1-2        0.95 Henries
                   1-4        0.71 Henries
DC Resistance 1-2      23.7 Ohms
                         1-4      20.8 Ohms
For measurement I can use a Fluke 77 or better. Tell me what you would like.
I will await your instructions as you said by email.
Kind Regards
Mr. Vortex
Vortex1
QuoteDr Gree is offing a $250 000 bounty on gravity ! So do we have an agreement on a 50/50 share of that reward ? hahah
I don't know any Dr. Gree, nor have I entered into any agreements with him.
You should work with him directly and let him pick up your working device, which I assume you have. Then no need for a 50/ 50 split with me, and besides that, I'm not interested in anyone's money. I'm into this for sheer scientific curiosity.  8)
you said:
QuoteWhat you will end up with is the world's first technology that will constantly measure earth's gravity and it will also be the most advanced detection system for earthquakes and will have ground to space flight ability
Actually, if it worked it would be the second such device as I assume you have already done all this work and have the first. It seems logical that if you have already a world changing device and if you want to "save" the world", as you say you do,  why not just publish it? Why delay another day?
I cannot tell you any more about the length of the wire, it is all in the specifications I have given you twice, and I'm not inclined to unwind it to measure the length of wire, as I will never be able to rewind it as neatly as the machine wound version.  I gave you the calculated length via core measurements so it will have to do:
Length of Wire (on the core) = 250.82 feet (3009.78 inches)
Dimensions of the core:
QuoteIMPORTANT !
We need a 3rd output wire, but this one is attached to the core itself !  You will need to drill a small hole behind the connection plate into the iron and screw a connection into it very tight ......
If this was important, why was it not mentioned at the outset?
I can drill a hole in the variac. Send a drawing or a complete specification with the depth, size, screw type, location and inch lbs to tighten so there is no textual confusion.
QuoteWhen you run it is your grid power always a perfected 60hz and does yours grid volts ever fluctuate ? even by a small amount ? This will determine the best time to do the short .
I'm sure you are aware that all  grid frequency and voltage fluctuates. You need to define "perfected 60Hz" in engineering terms. So the answer is yes.
Would you kindly also send an actual schematic, build and test procedure, along with your own tests and comparable data so we know what to shoot for?  Also, so we don't have to play hide and seek on this device testing, as the target build and testing keeps changing.
Regard
Mr. Vortex
