THE BEST FREE ENERGY GENERATOR
Started by magnetman12003, September 26, 2016, 01:02:12 AM
citfta
If you try to build it you will soon realize it is a fake.  Magnets don't work that way.  A lot of us have been doing this kind of thing for a few years now and have seen all kinds of fakes.  This is one of them.
Respectfully,
Carroll
Danglies
This looks very interesting. I dunno if you guys saw this video he posted https://www.youtube.com/watch?v=NQ998LjYre4
He made one using a CD case and CD with the same magnets he claims to have made himself, (By which I mean he made the 'shielding' for the magnets to direct the flow of the magnetic field) and it looks pretty convincing.
I read through the comments and it seems he isn't allowed to tell anyone how he made his special magnets, so even if it is a real device I don't think it is of any use. Unless someone can recreate his magnets?
Someone in the comments suggested it was magnetic putty in a case as when you reverse the polarity of the big magnet he uses, it doesn't change the direction of the fan.
Zephir
It's not apparently only magnets - they're covered with some material, like the permalloy - which would shortcut the magnetic circuit of small magnets until large magnet wouldn't saturate it. Did someone of you tested such a combination already?
"There will always be the same spinning direction. It doesn't matter whether the magnet is under or above the generator. It matters on the angle of tilt. If those magnets had been tilted on the other side (-50° instead of 50°) the generator would have been spinning opposite direction"
Very strange if true, but very common if faked... - most common way of faking of PC fan based magnet motors with stream of air https://www.youtube.com/watch?v=M1l_0J8g6w0
Edit: Tech Torr just presented another video, this time I'm willing to accept it's fake definitely https://www.youtube.com/watch?v=Go4ZfOvN4zs
Zephir
At the very end he accidentally revealed the battery mounted into his multimeter. He reuploaded whole video just because if it, but I already had a backup   https://i.imgur.com/WN3r18Z.gif  https://www.youtube.com/watch?v=vUWvOWkPgK0
Zephir
Another demo of "magnetic resonator" of the same guy. This time probably utilizes hidden battery even inside the LED bulb. It's not so difficult to insert such a battery into light bulb too - there is lotta space at the bottom, as Feynman once said ingeniously. But the voltage drop along spiral looks intriguing.
https://www.youtube.com/watch?v=NxKZbRnhH6g
