Using geometry to multiply rotations = multiplying AC electricity
Started by that_prophet, January 12, 2015, 08:06:05 PM
that_prophet
Quote from: citfta on October 16, 2016, 04:53:59 PM
Your device is useless!
Thank you, for such helpful words
free energy is done using pulleys
http://free-energy.yolasite.com/
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
citfta
MOTORS DO NOT RUN ON A SPARK OF ELECTRICITY!!  You seem to have plenty of time to waste posting your foolish ideas, why not spend some of that time trying to learn something useful.  Study the links I gave you to learn how motors and generators really work.
massive
Low-Q
Quote from: that_prophet on January 12, 2015, 08:06:05 PM
Come on guys
Let's get with the program
This works, and is so logical that it must work
You put a very small amout of DC electrity into a motor
That has a large 100 cm circumference pulley + only has to rotate once
Then you use a belt or strap to connect it to one or more mini pulleys,
That are of 1 cm circumference, which rotate 100 times + have AC motors
So you put in 1 unit of DC electricity
To gain 100 units of AC electricity = 50 – 100 electricity multiplier
please remember, you could add many mini pulleys
multiplying your electricity by massive amounts
dont listen to satan`s torque arguements
think of how easily mini motors turn
it takes practicallly no effort
This is not only free energy from God =(Eze 1:16)
DIAGRAM + DISCRIPTION @ http://free-energy.yolasite.com/
So, not only do we know free energy as Truth, but it is also good news in 2 tways
1) This will take away massive sums of money given to nations growing terrorists
+ This is info from The Big Guy Himself, so
2) This was found as a description of the workings of a UFO, so we should be able to discover antigravity, or be able to figure what ever helps these UFO'S levitate + travel so fast
(EZE 1:16) The appearance of the wheels and their work was like unto the colour of a beryl: and they four had one likeness: and their appearance and their work was as it were a wheel in the middle of a wheel.
as in, a little wheel inside a big wheel, but I could not afford to buy a big wheel with threeding on the inside, and a mini wheel with the same threeding on its outside. So I did the next best thing, I connected a big wheel to a mini wheel through a belt, stap, rope or even a piece of string in a pinch to connect the two pulleys with motors attached. This was easier to build out of many parts that one might have around, especially for the Tribulation Saints, when they are running from the evil authorities = in less than 5 years. http://my2020vision.yolasite.com/
Please remember this, when before 2020 the Tribulation starts = 7 year peace treaty signing with Israel = START OF TRIBULATION
Please view all the info that I have picked up @ http://beliefstoliveby.yolasite.com/
He gave me these two other Gifts also @ http://ultimatejoysticks.yolasite.com/
(an awesome next generation joystick = measures movement in all three axis's + measures rotations in all three axis's = that's 6 movements = 3 times basic joystick) -
AND http://ultimatevideogamecontrols.yolasite.com/
(which is awesome 3D virtual reality room = video on all 4 walls + ceiling + floor )
These are all free for all to use, as they are displayed on the web + are without patents
We should use these to earn plenty of income to help http://fire-starter.yolasite.com/ spread the Gospel.
Before http://my2020vision.yolasite.com/ occurs, before the
Door closes on Christ return http://doorschristmustpassthrough.yolasite.com/
Now first off let's loose this fairytale of EVil-sOLUTION
God proves it wrong with His Creation Hourglass = MOON= it only has 6000 years worth of sand on it,,,,,,
http://decimationofthisevolutionfairytale.yolasite.com/
free energy
The only reason that this has not been used earlier to create free energy, are the billions of fallen angels, trying desperately make sure that we never discover this technology
The problem is that Satan are right about his torque arguments...
that_prophet
if you attach a 100cn circumference pulley to a DC motor
it only takes one spark of DC current to rotate DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley then.
you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have practically zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential  = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC + DC electricity
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
I happen to be Born Again + want this super simple free energy technology out
before the first Door closes for Christ to return in the clouds by or before 2019.04
It warns us that no one knows the day nor hour... but it says that we will know
when it is near... near to what? maybe the door.... as we can know "even at the doors"
This way the Tribulation Saints have it to keep warm in our cold Canadian winters
even off the power grid. (remember fires would give away your position)
Doors are plural because He does show up twice = Rapture + at end of Tribulation
