Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1010 Guests are viewing this topic.
dewetw
Wahahaha  ;D Good one!
Here is his video on testing the final warp drive of his UFO, see it really works...
https://www.youtube.com/watch?v=APtgWuJYqzc
GeoFusion
Quote from: NickZ on October 26, 2016, 12:49:26 AM
  GeoFusion:
  After reviewing your last videos, it looks like you might have lost the ability to light the bigger 300-500w bulbs, when you changed your bridge rectifier to the simpler two diode type.  Could that be so?
  Watch that you don't touch the big white AC capacitor, with 250v on it, as it could knock you out.  I did that on my full bridge rectifier's capacitor (400v, 200uf), and it was no fun.
  Also, I believe that one of the reasons that you can't light the bulbs any brighter, than what looks to be about 25%, or so, on the bigger bulb, may be due to the diode that you placed on the PS.  The diode may be limiting the output from the PS to only 3-5A, instead of 15A that the PS can provide. So, I would recommend that you should try a bigger 15 amp diode, instead, or one that matches the output levels of your PS. IF you place only a 3 amp diode, on a 15A PS, and are drawing 4A from the push-pull by itself, and another 2-3amps from the Kacher circuit, for a total of about 6 to 7amps or so, that may be why the diodes are burning out. And the output lumin levels only drops with each additional bulb. Placing any additional bulb(s) which are only all sharing the SAME limited output from the PS, that can also drop the output voltage levels, as well.  Or not?
Ruslan is using higher capacity diodes on his PS now, also.
   I can wait for your feed back loop to be connected up, and you showing what it can do.
I'm still holding my breath, and I'm starting to turn blue.
Just kidding.
  Nice new push-pull and Kacher driver circuits.
  Please say hello to your Serb friends, for me. And give them my thanks for helping you out on those new drivers circuits.
Hi Nick
nah :), relax I still have the setup with greater output still there.
and more powerful now.
The last video you see is a old recording with those two diodes, I just made it public now on the channel.
That is the original hook up as how to follow Ruslan's diagrams. It's another Setup type.
with the 2 diodes facing with
kathode to yoke. but it's to show it works and did not continue on that path but it works :).
I think If I tried to loop it then with that setup it would. might try it out.
But something is missing and working on it with Arunas and some others.
Missing key :). thanks to Adrian Guska on his last recording made things more clear for me.
might be time now :D
Yes the bigger 30uF cap can charge up till 350V, it's nasty when to short it
but shows how much I can connect to load ;)
The recent one was this
https://www.youtube.com/watch?v=1OSpeWlR2Qg
PSU is only taking les then 24V 5 amps in complete consumption with kacher and PushPull.
not up till 7 AMPS. nor 15. you can see in video.
The blocking diode is when I have it looped, it's not necessary now.
And yes need better diodes, I have, will be placing it ;).
Ofcourse lumins drop a bit everytime you connect more load,
same for all other free running devices , just like Adrian and Ruslan, They connect more
and the lumins drop a bit,
But there is a moment I reach a boundary where the lumins drop drastically when connecting so much load,
you'll see the amp meter at input also decrease instead of increase. every time adding more load.
Yes, very soon it will function as what we all been expecting it to be. upcoming weekend I will be
on bench again to further experiment on :).
Yes,Those Circuits came in handy and are replica of my own home made pushpull but just now nicely on pcb.
Good guyz they are for sure :).
Ibrahim :),
Awesome to see you back to share some of the awesome demo's :D
Lets continue.
All,
TIP
,, What happens to a Tesla coil field in oscillation when it collapses ;)?,, when it get's interrupted, What happens afterwards,,,
sink in and think..
Cheerz~
AlienGrey
Quote from: Sequental.9 on October 26, 2016, 09:29:26 AM
The positive wave position for a coil is always a 5th of the length of the coil if the coil is in inches ! All frequency is spread over the length of the coil and is much easier and more productive if in imperial measurements... You just send that position to ground . You can simply keep adding coils connected to the 5th to build up energy !
I am working on a lawn mower zero point self runner hahah
S9
the lawn mower device is 10 or more years old you need steel fitters tube for this device the guy who invented it went to prison for 3 years for showing how it works. You have to pass the fuel though the centre of the exhaust to a supper steam to get it going.
Watch video   https://www.youtube.com/watch?v=lSiShiu9Sgs
AG
lacphong
Hi mgpwr,
Good you see you back.  I'm wondering what's the size of your Nanocrystalline toroid?  I'm thinking about buying one of the 86mm or 95mm one, but from many of the pictures and videos you posted it look like it's the 136mm.  Very expensive!  LOL
Thanks,
LP
Quote from: magpwr on October 26, 2016, 10:10:01 AM
hi,
Can you just upload a youtube video of your lawn mower in action.I hope that it won't sound like a typical engine. ;D
I am not even asking for the inside view or schematics at all.
That's all. 8)
AlienGrey
Quote from: T-1000 on October 26, 2016, 10:58:09 AM
Just "phrases list" instead... :D
I bet the 666 makes it a bit of a beast then!
lawn mower / geet engine  https://www.youtube.com/watch?v=lSiShiu9Sgs
Also Solar to PW up converter 5 > 13.5 makes use of low sun light.
Did anyone notice the full moon 'lunatic activity' increase over the period last week and the weekend starting with a peek on the Friday the 21st ;))
AG
