The over unity of series to parallel recharging.
Started by spacecowboy, February 09, 2017, 05:29:01 PM
spacecowboy
Made a little video on the over unity of series to parallel recharging with some demonstrations the average laymen can try. https://www.youtube.com/watch?v=VTA7a9l7Ifo
dieter
Interesting, but did you say whether you did test this successfully?
The motor is also interesting, it may cause some AC signals and cause high voltage spikes on both sides, some recharging the serials, he others, rectified by the diode the parallels. Similarity to Bedini to some degree.
Would be interesting to see some layman, actually perform this experiment.
Current flows from a higher to a lower potential. Where in normal consumption electrons and ions  are exchanched and eg. in a voltaic cell oxidize one side, doing it this way you are practically causing flow between two similar metals. I'm not sure tho, whether this is also valid for alkaline or LiPo etc.
Tito L. Oracion
we need to cut one wire in the motor and get the collapsing field and charge. [/size]
