TD replications
Cairun
Quote from: gotoluc on February 25, 2017, 05:16:50 PM
Hi Alex,
Thanks for sharing your very interesting mechanical gear timing system.
I'm always amazed as just about any timing and motion can be accomplished with gears.
Glad your here as you're a great asset to the research.
Luc
Luc,
You are very welcome!
I am glad to be a part of the research.
I hope my contributions can help to further this research.
Alex
Cairun
Quote from: Floor on February 25, 2017, 02:22:38 PM
http://www.dailymotion.com/video/x5d7hdv_lucs-1_tech
hlttp://www.dailymotion.com/video/x5d7ip9_lucs-2_tech
Floor,
Your setup in the the second video is very interesting and got me thinking.
If your put another set of output magnets with south and north poles reversed
on the left side of the input magnet then you would have 2 output strokes and get 2x the output.
Furthermore, once the input magnet is pulled out, the output magnets would self reset since they
are in attraction to each other.
Now to get 4x the output, you can put another input magnet on top of the the current input magnet
with south and north poles reversed.  This serves to double the output stroke force.
This is very exciting.  I wish I can test it now but I can't since I will be working away from home for the next month.
Alex
[size=78%]
[/size]
[size=78%]  [/size]
Floor
@Cairon
Thanks, and see you when we do.
@GotoLuc
Simple is best... short of continuous rotation
            and simpler !
lift a 4 pound seldge hammer head ... in 2 foot increments...
by lowering a 1/4 pound weight 6 inches....untill the
1/4 pound weight has lowered a total of 30 inches and
the 4 pound weight is ten feet in the air ???
or whatever the maximum ratio can come out to ... via a single
cascade.
Do it your own way ... I hope this might be some contribution.
                      .... in pdf form.
                      floor
Cairun
Floor and Luc,
Even though I can't conduct experiments while away from home.
I will continue to design a self runner using Luc's setup(in a linear reciprocating desing using 2 slides).
I hope to finish design and order all purchased parts before I get back home
so I can start the build immediately when I do get back.
Alex
gotoluc
Great Alex
Maybe all I'll do is put the 2 slides together to test the results using the 6" ceramic magnets and wait to see your mechanical design.
Thanks for staying on it.
Luc
