synchro1
Quote from: Magluvin on April 17, 2017, 04:31:22 AM
Syncro. Brad and I are moderators here. You need to put up or shut up, to put it bluntly. Either show what your arguments claim or we will have to shut you off here.
You came into this thread at page 3 and claimed that the bifi has 2 times the inductance as a normal coil. Tk proved you wrong, and I am saying you are wrong. Get it together bud and I do not want to see1, 3, 4 and 5 posts in a row of bashing. You are accomplishing nothing but wasting page space. So it has to end here. Ok?
Mags
@Mags,
The "Watt Hour" was selected as the base unit by Joseph Hemry for his Inductance formula. Neither Milehigh nor Tinselkoala had any way to find this out because neither of them knows how to read or understand the algebraic expressions we use. Then we find them doing this kind of arithmetic in "Highly FIllagred Fashion". What's wrong with this picture? They refuse to acknowledge "Negative Henry Measurements", an indespensible units of force equivalency.
"Negative Current" is another unit of measurement they maintain is imaginary. Really now come on man? You don't want to stick up for these foppy show offs, with beat off cream on their faces, do you?
synchro1
Quote from: TinselKoala on April 16, 2017, 10:36:32 PM
It must be horrible to be you, baby doll. You are so insecure. You will lie, sling innuendos, make unsupportable claims and even Ainslie-troll threads to try to bury discussions you don't like, in order to salvage your pitiful insecure ego. You should have your doctor check your medications, because your paranoia level is off-scale and you are clearly in a meltdown phase.
I can clearly show that my connections are correct, and ANYONE, even you, can CHECK MY WORK and see if I am doing it properly or not.
And there is no mystery at all about any of Bedini's motors. By the way, this thread is not about Bedini motors.
@Tinselkoala,
He's using Quaqdfilars, two bifilars joined into one winding! So it's on topic. You attract people with shiny objects then club them like seal pups on the ice flow.
Magluvin
Quote from: synchro1 on April 17, 2017, 07:15:04 AM
@Tinselkoala,
Lets keep it to this....
"He's using Quaqdfilars, two bifilars joined into one winding! So it's on topic."
And if you are going to make rebuttal statements, show links or other sources for your arguments please. This way it is harder for your statements to be frowned upon just because it is coming from you. Makes for less unnecessary back and forth filling pages. ;)
I already warned you once, but it doesnt seem to sink in. Keep it clean or, well you know. :(
Mags
Magluvin
Im not going to have time to play today.  :-[ I wana go out and play,Cuz Im a fan boi.  ;) Gota work. But I will be checking in periodically.
Mags
Quote from: synchro1 on April 17, 2017, 07:10:37 AM
@Mags,
Once again your insults and disparagement clearly describe yourself.
And you are having so much trouble typing in your childish rage that you can't even spell "HENRY".   You clearly have no idea what you are talking about. The WATT-HOUR IS A MEASURE OF ENERGY, in JOULES, not inductance which is measured in HENRIES, which can be expressed in Joules/Amps2.  They are in no way "equivalent" no matter where you stick your silly minus sign.
There is current, which is the flow of charge. It always proceeds from a place of higher potential to one of lower potential. Not the other way around. You can stomp your feet and add capital letters but that does not change the facts. The "negative" sign on your ammeters is there to show you which way the current is flowing, not to identify some "negative current".
But as I said earlier, since CURRENT is the flow of CHARGE, and charge in wires is carried by electrons, which have the unit negative charge, some nit picker could say that ALL current in wires is "negative" since it is the flow of negative charge. Nevertheless it still flows from higher potential (region of greater negative charge)  to lower potential (region of lesser negative charge). Only.
Really, Allen Burgess? You say things like that on this forum? Not only do you lie and misrepresent but you are now resorting to PORNOGRAPHY in your insults?
You are truly a sick, sick puppy.
In Texas we know what to do with animals as sick as you are. Someone will be along to remove you and your filth-slinging shortly, I trust.
