Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
wizkycho2
Hi all !
I would like to jump in with some theory (and 33A DC electrolysis expirience)
Why I think this pulsed setup should work ?
(I have all setup on a table and everything in place I just wait for some free time to give it a pace)
1. Mass of electron is tremendously smaller than mass of Atom Core of H or not to mention O(16)
2. therfore inertia of electron (as particle) is very small and if Our puls is not lasting for too long
only electron will move in Our electrolysis proces. Ions H and O will not start to move cause they are heavy and for them to
start to move (towards plates) pulse needs to be much much longer (especially DC)
Whay is that important ?
most importantly they will group on plates in such manner that they
form voltage layer opposing Our voltage
. Allso when moving they genarate heat and lowers conductivity.
Allso Our cells are like condensators but with additional property that after charged it discharges itself (through time)..
Giving that pause we give time for Ions to stabilyze (ensure they stay in place not moving much) and cell to discharge so like in
condenser our next pulse can be at maximum current like in start of charging normal capacitor.
Liquid Accumulators acts simmilary when discharging or charging with pulses (ions move very little not sticking to plates) they behave
incomparably more efficient than in situation when char/discharging with DC.
In situation when such sistem is pulsed (and paused) Ions doesn't have to carry charge (electron) but rather passing it to next Ion.
They form a chain much like chain when people carry a buckets of water in a line passing it to one another (only first taking water
from well, only last distingushing fire)
Many chains are formed parallel (as much as there are wells and fires)
...People don't move but only the water in a bucket...
Igor Knitel
Perihelion Labs
coolwater
Hi all, keep up the good work, can some post and actual pic of the coils not a mud map, im have trouble wing hundred turns of wire on to an inch of ferrite rod bugga is the word thats comes to mind, also tuning the tubes can this be alliminated by using a plate system with identical dimension plates the resonance of the plates due to exact dimensions should be the same therfore eliminating the need to adjust resonant freqancies can some one confirm of deny this for me,
Also just a therory has ne try to send a PWG thru an auto motive coil (up to a 35kv charge into cathode at pulsed freqency, or even a motorcycle coil about 20kv) an other idea was to get a igntion system off a 4,6 or 8 cylynder car and setting up 4, 6 or cell setup in the same enviroment and run the ignition system in cycle thru each cell in a cycle,
Can / has ne 1 investigated this already if so let me know by post or email
Thanks Agian guys I think were gettin closed to breaking free from the Corperate giants,
Troy
Gheller J
Runningbare>>>
That schematic was supposedly made for Panacea replication by you know who!!
Gh. J.
RunningBare
Err, Gheller, the picture is signed  ;)
Quote from: Gheller J on September 20, 2007, 08:28:08 AM
Runningbare>>>
Gh. J.
Gheller J
Coolwater>>>
Check d pic of inductors posted on Page 19 of dis thread. They r more than a few inches long!
Plates supposedly don give u d same efficiencies as pipes in dis process.
Som1 i kno has tried autocoils it didn work
u dont dump HV in a shot this cud create arcs like on spark plug
u need step pulsin
go through stan full details pdf see VIC drawings n writeup youll get d picture.
Gh. J.
