Curiosity on chemical process
Started by franco malgarini, September 17, 2016, 01:28:12 PM
franco malgarini
franco malgarini
Using passive thermal diodes, the COP of the system is infinite, considering 100 20 watt peltier cells,
You have 2 KW free ...
I do not think that this will be so easily resolved and
you need for the Peltier-Elements the energetic hot/cold-source.
Your given information is the newest estate in the  MEMS-converter and Nantenna research and development,
I would say at first really usefull as passive(active ?) cooler and heat converter in CPV-systems.
The "dernier cry" would be "paintable thermal diode dots" !
Probably helpfull for heat-related energy conversion :
Sandra Salome Casillas Bolano "superconductive ink"
https://phys.org/news/2015-10-superconducting-ink-instantly.html
And here another idea,
what is possible with such a coating ? :
https://www.patentauction.com/patent.php?nb=11044
We added our heat increasing formula, Combo 3, in see-though glass and painted a glass with it.  We realized it increased the heat 7 times by holding it on the siding during winter. After testing the heat amount on the siding with digital thermometer, we saw the siding that was not under the glass was 32 degrees, and the part under the glass was 230 degrees showing a 7-times increase. It is possible to increase it more.
We noticed, when we use our combo 3 on multiple layers of glass, heat increases with each layer.
                                   So there is no limit to how many times we can increase heat.
Combo 3 increases heat which is a light and color (infrared), but slows down the speed and lumens of the light. (This is not important, because light is very fast and we need the heat not the light.)
For heat and cold side :
12.   Use product inside thermoses, freezers, coolers, coffee cups will make the heat and cold last at less 5 times longer.
Sincerely
             OCWL
profitis
2Fe(CN6)3- + 2OH- >catalyst< 2Fe(CN6)4- + H2O + O
Temp T
