Tom van Keulen coil v9 setup free open source
Started by indigo22, July 26, 2017, 07:19:54 PM
wistiti
A  tutorial video will be really nice!
Righ now im not really sure to understand what you are doing with this setup....
I have give a look to your site but did not find the info.
Thanks!
indigo22
wistiti
Where is the output? Is it the 160vdc to batt on the right or the +/- at the top?
Do the battery are conected to a real ground in the soil or between their negative legs?
Also not sure to understand the pwm.
indigo22
whow lot of questions no problem, if i was you i would start with the v2 version show in this picture the plus from the batterie goes to the bias to create 2 northpoles inside the coil, then 1 becomes the plus and 1 becomes the minus with a diode ofcourse the second bifailar winding can be pulsed in 1 direction that's why i adjusted my new design but if you wanna recreate my setup do it bifailar i use the wires from the john bedini coil i don't realy know what gauge that was i think 23 aand 26 but i'm not sure, i put the plus to the batterie let it go trough the coil then into the pwm with breakoutbord and pulse it back into the ground, this creates a falling of a magnetic field witch induces a radiant spike
indigo22
this v9 is not tested jet it's just a rough scetsch the v2 work 110% but i'll take you trough it https://www.youtube.com/watch?v=vOqn5ggPjJ4
