Resonance Circuits and Resonance Systems
Started by hartiberlin, March 15, 2016, 03:27:11 PM
Quote from: Magluvin on September 16, 2017, 05:29:16 PM
With just a bit of fiddling I changed the sealed internal enclosure to .3cu and the larger ported enclosure to 4cu. just changed box sizes.
123.37db@1w    That equates to 1370.88% eff of input vs output.  :o ;D   Can anyone tell me if Im wrong here? If so please provide sources and references for your arguments.
Mags
https://www.google.com/patents/US8004250
Low-Q
Mag,
I can't fully understand how you can get overunity out of a resonance system.
It's easier to understand the resonance concept by using a low loss spring, and a mass attached to it. The spring is the capacitor and the mass is the inductor.
If you try to extract output from the mechanical system, you also remove the reason why it resonate.
Say you put cotton whool inside the spring. The cotton is the load you want to put energy in to.
Now the resonance system has a low Q, and is no longer willing to sustain oscillation without energy supply.
My nick, btw, reflects this low Q as a speaker system with controlled audioable output. You cant get controll without effort.
Vidar
        Good morning,Low-Q
question and answer source : probably ( ::) ) https://de.wikipedia.org/wiki/Reginald_Fessenden
                                                 https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=us&AP=&PR=&PD=&PA=&IN=+fessenden&CPC=&IC=&Submit=Search
less (easy,simple and uncomplicated) and fancy if you understand french (frank und frei) :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=louis+charles+beaupre&CPC=&IC=&Submit=Search
compare( if sufficient freetime avail):
https://worldwide.espacenet.com/publicationDetails/biblio?FT=D&date=20040219&DB=EPODOC&locale=en_EP&CC=JP&NR=2004056987A&KC=A&ND=5#
https://worldwide.espacenet.com/publicationDetails/biblio?FT=D&date=20050616&DB=EPODOC&locale=en_EP&CC=JP&NR=2005160215A&KC=A&ND=5#
Profil(e) "Tanaka Saburo" ?
                              Lord Kelvin capacitor/metal spring analogon
                              https://en.wikipedia.org/wiki/Charge_pump
        in-/con- version
        actio  -         ?                 reactio
        active-         ?                 passive
                                                            emission-   antenna             receiving
https://cleantechnica.com/2011/09/20/okayama-solar-absorbers-use-%E2%80%9Cgreen-ferrite%E2%80%9D-to-generate-super-cheap-electricity-from-heat/
                                search for Naoshi Ikeda et al. and their cristal phaenomen/effect findings and development
http://www.astrofoil.net/     http://www.astrofoil.net/astrofoil.insulation.tech1.html
                                             RADIANT ENERGY TRANSFER DEFINED
                                             transfer or telefer,trans-port or tele-port
                                             http://www.astrofoil.net/astrofoil.insulation.r-values.html
                                             http://www.astrofoil.net/img51.gif
                                             " ...... emit infra-red rays,which have no temperature ....."
                        anergy and exergy = complete energy
             http://www.udo-leuschner.de/energie/e00inhalt.htm
                               google translated
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.udo-leuschner.de%2Fenergie%2Fe00inhalt.htm&edit-text=
                                  e-specially
             http://www.udo-leuschner.de/energie/SB102-07.htm
                               google translated
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.udo-leuschner.de%2Fenergie%2FSB102-07.htm&edit-text=
http://www.energie.pt/en/ based by Jacques Bernier invention,1997 also sold by com(m)ercial name : Axergie
https://www.amazon.fr/La%C3%A9rosolaire-pompe-chaleur-assist%C3%A9e-solaire/dp/2862431109
and more :
https://www.google.pt/search?q=jacques+bernier+pompe&client=firefox-b&dcr=0&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwit35OM_KvWAhXlJsAKHckKCfMQsAQIVQ&biw=1366&bih=667
                    energy:                             decelerated becomes : matter/materie/material
                    material/materie/matter : becomes accelerated  : energy
                    https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1#
                       Andrew Crosse: Abiogenesis of Acari - Rex Research                      incubator ? teleporter ? energy or materie-converter ?
                                    not such important-the answer- then the free energy device in house
Have a good Sunday and a nice successfull week
        OCWL
Belfior
playing around with capacitors and non-polarized and polarized (electrolytic) is pretty clear, but how about frequency? Can I use just any cap with 50kHz AC or square wave? What if the voltage is is in the range on megahertz?
What if the pulses are square wave from 0 to 5V of 50 kHz? Is that considered pulsed DC and AC only when it goes negative too?
Some of these signal / power sources are pretty unclear what they mean when they say AC or DC. They say AC if it is something else than a constant 5V
Quote from: Belfior on September 17, 2017, 07:37:48 AM
     DC , pulsed DC ,square root AC, sinusoidal AC :
     (universal ?) consumer drive freedom degree
