The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
Grumage
And a happy New Year to you and all in the " free energy " research area.
This is the direction that I'm currently taking.
http://www.overunityresearch.com/index.php?topic=3577.msg66279;topicseen#msg66279
Thoughts/comments?
Cheers Graham.
Cadman
Now that's interesting!
Perhaps bring a positively charged plate very close to one side of the hot wax. If the wax was in a  grounded mold then it should become negatively charged. Keep the positive influence close until the wax hardens.
If the wax would actually lock in the negative charge state then you would have something like an electrostatic magnet.
Grumage
Dear Erfinder.
Thanks for sharing the demonstration.
You open showing that there's no continuity between the windings of your machine and the output terminals. I assume that your machine is " commutated " either mechanically or electronically to achieve this?
Cheers Graham.
Your demonstration proves nothing, illustrates nothing, because as usual you do not provide enough information to determine what you are showing and whether it is actually interesting or not.
There are any number of ways to produce what you've shown in your video. For example, just a simple, small, spark gap, off screen, in series with your wiring to the welding rods would allow you to show the same "zero conductivity or continuity" and "infinite (not "zero") resistance" readings from the meter. Then when you turn the device on and draw an arc from the visible welding rods, this small offscreen gap would of course be bridged, allowing continuity to the welding rods on-screen.
So you've demonstrated only that you have a high current output along with a small degree of HV necessary to jump a tiny gap. And that your power supply is somehow associated with a noisy motor that cannot sustain RPM when under the load represented by the short-circuit arc or the halogen lamp load. What has this to do with anything discussed in this thread?
Cadman
Erfinder, thank you for increasing my comprehension with that video. I am not blind, nor deaf.
One thing that has always bothered me is the textbook explanation of cemf in a coil. A voltage is produced in opposition to the applied voltage. I always wondered; Produced? From where? How? I have an inkling now.
I wish I was around when you posted all of your other videos.
Respectfully,
Cadman
