Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Void
Quote from: SolarLab on January 15, 2018, 08:06:06 PM
The Genesis Project is but one of the probably thousands of alternate energy related
developments that have been going on since Tesla's days. Peaking around 1985 and again
around 2001, or so - many hundreds of ideas have been proven (?) to operate as claimed.
Hi Solarlab. You seem to have taken my specific question asking if anyone has more info about
'The Genesis Project' as a general question about OU research.  I am actually quite familiar with
the whole 'OU research' scene and have been involved myself for quite a few years already.
I was really wondering if anyone knows more details about 'The Genesis Project' specifically.
Does anyone know if those devices shown in the document have ever been demonstrated on
video or elsewhere, or know any details about who built those devices shown in the document?
All the best...
Quote from: Zeitmaschine on January 15, 2018, 07:10:04 PM
core: »What are you guessing is the fuel source?«
The negative charge of the electrons.
A QUICK SUMMARY OF THE COMPONENTS WE HAVE IDENTIFIED SO FAR
1) A frequency doubler circuit. There is no other idea what those parts hidden under Stepanov's cardboard box else can be.
2) A high voltage transformer. Even in theory, without experimenting, it is clear that the high voltage secondary coil of a transformer can attract electrons from ground when connected to ground at one end.
3) Another transformer with a shorted secondary coil. Not because cosmoLV just says this, but because we can see it in the Barbosa-Leal demonstrations and also in the patent.
4) A spark gap. Most likely NOT used, because the Kapanadze device is the only device of this type which purportedly needs one.
When an open secondary coil of a transformer generates voltage, then there is a surplus of electrons on one end of the wire or on the other end, alternating. But those electrons do nothing. First the circuit has to be closed, then those electrons start to generate a magnetic field and heat. That means, if electrons are attracted from ground, they also do nothing. They have to be injected into a closed circuit first. But nevertheless the source of those electrons stays an open circuit, namely the high voltage coil connected on one end to ground. Here Bearden's theory comes into play »Don't kill the dipole«. No, we do not kill the dipole of the high voltage coil, because it is not a closed circuit. Further reading:
THE SECRET OF ELECTRICAL FREE ENERGY
»The bird sits on the high tension line without a flow of mass electricity, because there is no significant difference in potential drop between the bird and the line. Specifically, between the birds two feet -- each in contact with a different portion of the line -- there exists no potential difference. This is true even though, with respect to the vacuum, each foot is at a potential that would be "100,000 volts higher," were a mass current flowing.«
»Now notice what would happen to the bird on the line [THIS IS THE TRANSFORMER WITH THE SHORTED COIL] if we substantially "pulsed" the potential on the line [BY MEANS OF THE HIGH VOLTAGE TRANSFORMER]. Suppose we "pulsed" it such that the bird's physical system -- considered as a circuit containing a capacitance, a resistance, an inductance [NO SUCH LC CIRCUIT NEEDED, SINCE WE HAVE ALWAYS RESONANCE THANKS TO THE FREQUENCY DOUBLER CIRCUIT], and many free electrons -- became resonant to the pulsing frequency. In that case the "bird system" would resonate, and a great deal of electrical mass would surge back and forth in the body of the bird [IN THE SHORTED COIL]. In the bird's body, voltage would exist, charged mass current would flow, work would be done, and the bird would be electrocuted [THE IRON CORE WOULD BE MAGNETIZED].«
»In every conductor, a large number of "free electrons" are available. If we oscillate the actual vacuum charge itself, unlimited additional free electrons also become available from the Dirac sea, since partial "unstripping" of the negative energy wells (each containing an electron) occurs. This "unstripping" of the potential of the well is due to vacuum potential oscillation, which oscillates time as well as space. To a negative energy well (positive time), the oscillation [AT 100HZ] of its "time stream" increases the well's negative potential during one half-cycle and decreases its potential for the other half-cycle. Thus during half the oscillatory cycle, negative energy electrons may be lifted [ON THE HOT END OF THE HIGH VOLTAGE COIL] from the Dirac sea if the oscillation is sufficiently intense [THE VOLTAGE IS HIGH ENOUGH].«
So, if this does still not work, then perhaps there is one more component of the device that needs identification.
Here:
Partial demonstration:
https://www.youtube.com/watch?v=AFP6c7lwyoE
Void
It's time to break this wide open, once and for all...
Electrons schmecktrons. This is the real secret.
;D
forest
Quote from: core on January 15, 2018, 04:43:48 PM
(...) You still need the energy source to store in the field.(..)
-Core
How about electric current store magnetic field into iron core ? How about this core being inside Earth ? :-) So...? Now we can't tap permanent magnet energy ,right ? What if ....it's not permanent but electro-magnet ?
Jeg
Void :D :D
Hi Zeit :)
The two transformers schematic is very interesting. If i recall right you have said that resistor and capacitor are responsible for the doubling of frequency. The reason of doubling is due to the full bridge rectification. I just wonder what is the role of resistance over there. Is there any idea? Ιn addition, does anyone know where to find a transformer 220 to 2000V except of MOTS which consume one ton of wattage?
