Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
tomd
For those not familiar with Fernandez's posts then here they are:
https://overunity.com/17535/kapanadze-stepanov-barbosa-leal-and-the-secret-of-free-energy/msg516346/#msg516346
https://overunity.com/17535/kapanadze-stepanov-barbosa-leal-and-the-secret-of-free-energy/msg517669/#msg517669
This is my interpretation of Fernandez's Transformer:
First of all, the circuit is similar to a single phase electric motor.
https://www.youtube.com/watch?v=pbg_PF6MTwY&t=326s
   The two phase shifted current pulses (magnetic pulses) would result in a third magnetic pulse which is out of phase with both. This third magnetic pulse induces voltage and current in the secondary. The magnetic pulse from the secondary (cemf) is therefore out of phase with the two primary coils. This would result in little, if any, cemf reflecting onto the primary - how much I'm not sure. Also I'm not sure why only DC pulses and not AC. How would the core not saturate?http://astronomy.swin.edu.au/cosmos/C/Constructive+Interference
This is how I see the circuit. "It's so easy you will laugh".
leonelogb
Thank you Tomd  :)
I still seeing the same in Tesla patent 382,282 check it...
Quoteit will be observed that at a given point of time the coil G is in its neutral position and is generating little or no current, while the other coil, G', is in a position where it exerts its maximum effect. Assuming coil G to be connected in circuit with coils B B of the converter, and coil G' with coils B' B', it is evident that the poles of the ring A will be determined by coils B' B' alone; but as the armature of the generator revolves, coil G develops more current and coil G' less until G reaches its maximum and G' its neutral position. The obvious result will be to shift the poles of the ring A through one quarter of its periphery. The movement of the coils through the next quarter of a turn, during which coil G' enters a field of opposite polarity and generates a current of opposite direction and increasing strength, while coil G is passing from its maximum to its neutral position, generates a current of decreasing strength and same direction as before, and causes a further shifting of the poles through the second quarter of the ring. The second half-revolution will obviously be a repetition of the same action. By the shifting of the poles of the ring A a power-dynamic inductive effect on the coils C C' is produced. Besides the currents generated in the secondary coils by dynamo-magnetic induction, other currents will be set up in the same coils in consequence of any variations in the intensity of the poles in the ring A.
leonelogb
UNTIL NOW I HAVE NOT OBTAIN GOOD RESULTS, ONLY A VERY, VERY HOT CORE(BOTH OF THEM CORE) :( :( :(
tomd
Quote from: leonelogb on August 16, 2018, 06:12:48 PM
That's because it's dc (rectified ac). I was hoping someone could provide a solution to this. If you try it without the bridge you shouldn't get the heating problem. However Fernandez makes a point that you must use rectified AC.
I'm not sure how to figure out the correct size capacitor. Trial and error maybe?
"BOTH OF THEM CORE" - There is only one core. Have a look at his core with the C clamp and soft iron rod.
leonelogb
Quote from: tomd on August 16, 2018, 07:43:53 PM
I don't used both together, one by one and different capacitor size!
I don't know why in energeticforum.com They Got It and here we CAN NOT :-[ :-[( Barbosa-Leal), I'M sure Somebody here know HOW this working!
