Perpetual motion track magnets and gravity
Started by juliotony, October 29, 2018, 12:13:41 PM
burnit0017
https://youtu.be/b6BzIO8zj3Q
Hi, this is another example using a electromagnet with a high voltage pulse, it may help. What diameter magnet wheel are planning to use?
Belfior
Quote from: burnit0017 on October 29, 2018, 05:59:56 PM
Watched the video. Oh man. I am trying to remove obstacles like friction to prove a concept and everybody else is using 1000kg devices?!? Could steal the pulse mechanism from the video though ;)
I think the size depends on the magnets really. What ever is needed to get enough electricity from the secondary wheel so it can be used as a pulse to repulse the last rotor magnet. That means the secondary wheel has to be large enough for the speed needed to get enough flux change. Larger wheel == more speed on the wheel edge == faster rate of change in magnetic field == more induced current
That wheel will also work as a fly wheel to assist passing the last magnet.
Also I think at some point the wheel may be too big. So the idea is to find the ratio where you can just pass the last magnet. This might also mean that I need to use mechanical aid to start the device. After initial mechanical aid the flywheel + electromagnet would be enough to turn the device
the most important thing is to build it and not just fantasize about it like I do. Then you will see if there is anything there or you just had a brain fart
