Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
F6FLT
Quote from: v8karlo on January 06, 2019, 07:46:45 AM
Ok. Your words sounds honest.Wesley is a good guy...
The road to hell is paved with good intentions.   ;D
AlienGrey
Hi V8kalo Not trying to cause waves or anything but the circuit of DC 1.1 i have doesn't work very efficiently on generating spikes to drive the Ferrox ring transformer :'(
Some of the guys having the same problem, It would appear some sort of noise gyrator device is required perhaps, I was thinking perhaps you could
show us your SG3525 and IR2110 circuit you used.
Many thanks, AG
Void
It tells no one anything much at all for someone to say a circuit 'works'. :)
This is overunity.com. We don't care if circuits light bulbs. We need to know how well they light bulbs or other loads.
The way circuit performance is evaluated is by measuring the efficiency of the circuit, (or COP of the setup, if it applies).
Efficiency is (Average Power Out / Average Power In) x 100.
Without such measurements you might as well be talking about the weather here.  ;D
V8Karlo claimed this about his 'Q Device':  "Most of the output energy is returned to source."
Itsu measured an efficiency of around 32.5% with his 'Q device' test setup. So the reality is the
Q Device wastes a huge amount of energy. It does not at all 'return most of the energy to the source'.
A circuit efficiency of around 32.5% is a horrible circuit efficiency. On the other hand, if you connect a 12V
light bulb directly to a 12V battery, you will have pretty much 100% efficiency. :)
NickZ
   It seams that what Karlo wanted is for someone to build his circuit, and confirm about the results being something anamolous, or not. But, so far there has been no indication that his circuit has merit. And the "little help" was not enough to make up for the losses. So, where do we go from here?
  Seam like ALL the different circuits that have been built up to now, are nothing but bottlenecks, instead. Showing low efficiency, no OU, nor self running.
   Will the real OU device, please stand up...
A.  explended power dissipation reduction
B.  the loop exists, called superconducting energy  storage f.e. EdF,France, Unity 1= storage
C. the free energy : physics term " random fluctuation" generator exists in multiple kinds,
mostly used as    photo- electric conversion device = vulgar " solar cell "
D. Comparision:
http://web.archive.org/web/20060615030624/http://www.1000inventions.com:80/country.htm
Nigeria : AUDIO POWER TRANSISTOR SOLAR PANEL
E. -ntertaiment : closed loop : donut type : bicycle inner tube  charging with air or water ?
                 and then ? overcharging ? "charging pump/ re/- actor " to "charge  bomb" ?
