Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
seaad
Please lancaIV test your suggestions before release.
I'm doing so mostly, not always.
But of course it's really easy to fool yourself
even with a test.
Regards Arne
Hello seaad,
clearly the opinion that the written processes has to be tested and appropriate constructed !
applied 1965, page 30 from the " original document" , related EMK or EMF and the Max./Min flux relationship   in correlation with " Lenzs' Law"( inverse : Flemings' Law)
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=1488837A1&KC=A1&FT=D&ND=5&date=19690313&DB=EPODOC&locale=en_EP#
For 2 KW output only 75 Gr. permanent magnet weight !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19761217&CC=FR&NR=2312135A1&KC=A1#
This as final theoretical input !
Wishing experimental success
OCWL
p.s.:    2008 in ES, Spain granted but now free            http://invenes.oepm.es/InvenesWeb/detalle?referencia=P200403033
           probably for interest his circuit
ramset
BUMP
underconstruction
Seaad has made a claim,of seeing an anomaly here ,I do believe he filed for a patent application [he wrote this somewhere here or another forum ??
regardless its good to investigate and very simple ...if I am mistaken he will correct me !
Chet K
Thanks Grandma
a.king21
Apparently Thane Heinz got the phase shift to nearly ninety degrees and claims infinite efficiency. Definitely OU claim.
https://www.youtube.com/watch?v=VwUAAKFd69s
https://www.youtube.com/watch?v=J8NunH9TzFk&list=PLFEHIlsTyqx_KlRsYA8NKBOwtNoYh7AGk
These 2 videos definitely worth  watching.
Seems it may work with ferrite cores.  I have plenty of these knocking around and will try to find the time to build it
within a few weeks.
Many years ago I rang Ottawa university and spoke to some students who had replicated and  were very exuberant on video.
When I spoke to them however they clammed up and were very nervous.  They sounded as nervous as when
I rang the Lutec guys in Australia.  So something is definitely going on here that the establishment does not want us to see.
EDIT:  I enclose a pic of the Thane Heinz trafo for  comparison..  the similarities are just too big to ignore.
Void
Hi Seaad and Ramset,
I looked up that patent and I see that it should be fairly easy to try to replicate that transformer layout.
I am attaching a drawing from the patent. I have too many things on the go already,
but I will see if I can get a chance to try to replicate it sometime in the near future.
See the attached drawing from the patent (DE102004029434 by Adam Lorek).
I added a few comments to the drawing for clarification.
a.king: I have tried the Thane Heins transformer arrrangement in the past and found that it did not work,
in the sense of being a useable transformer. It does show a large phase angle on the
primary due to the high leakage flux, but I found that due to this high leakage flux it was
not able to deliver anything other than a very tiny amount of power to a load. If that transformer
had really worked, you can bet Thane Heins would have been marketing it, but he moved on
to his electric motor device and he has been focusing on that, from what I saw.
