Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
ДЛR#775. Двуплечевая
https://www.youtube.com/watch?v=gRB5MXq1q0w&t=0s
You do not need a special cacher.
A special yoke transformer is needed.
And
If the grenade coil and cacher are connected directly to ground, the free generator will not work.
Do not be confused.
AlienGrey
color
AlienGrey:
I know.
Denis Permyakov operated kacher with two MOSFETs.
Looking at my MOSFET placement circuit.
So I pointed out that it is a push-pull MOSFET.
If the Ruslan Free Generator kacher is directly connected to ground, disturbance of the wiring occurs.
The disturbance in the free generator circulation system is a contradiction.
It is inoperable.
Minwell operates at 220V alternating current but its output is 12 ~ 24V DC.
Kapanadze was solved with an inverter (DC input - AC output) and a transformer (220V-12V)
Ruslan uses only the generator and Minwell.
There are no inverters and transformers.
At this time, the cathode and the ground play an important role.
The Ruslan generators and the Minwells operate in a unified structure rather than in an independent structure.
I understand why cathode and ground are commonly used even if only the generator circulation system is understood.
AlienGrey
This video shows a device using a vacuum tube it shows the build and windings but the schematic was never disclosed, pity!
https://www.youtube.com/watch?v=bNzFwHqI7fc
