Phonon boson and Higg`s boson interactions : Energy conversion in TPU
Started by Esa Maunu, March 31, 2007, 04:06:14 AM
Esa Maunu
Quote from: duff on October 10, 2007, 09:43:22 AM
Quote from: Esa Maunu on April 07, 2007, 02:29:52 AM
If we have a prime numbers for the wave numbers on cores circumference, it means that there can not be subharmonics  frequencies inside the coil circumference, because there is no combinations with number of waves/ wavelenghts that can build field patterns inside cores circumference. This means that there is no disturbing fields inside the core, that can affect harmful to control electonics.
Esa
Esa,
Does using wavelengths that are a prime number reduce the harmonics that can occur in sine wave oscillators or does this only hold true related to your above statement?
I enjoy reading your posts - your explanations are very informative.
-Duff
When  number of waves are primes in a circular path, there is no place for subharmonics to build up.
Input frequency must be coherent, if you have a input signal that contains many harmonics, it means that there are a lot of different frequensies, and some of those frequensies can form subharmonics frequensies.
Thanks,
Esa
Esa Maunu
There is one thing that tells us there is a force in a space ( zpe or more precisely dark energy ); it is a precessing effect for all mass that has a spin. Even earth, when it rotates , has a precession around rotating axis. This same phenomena exists also at quantum level, where almost all the particles have a spin. Precession is tightly connected to magnetic moment, that many particles have.
If we can put this precession into unbalanced state by external field ( phonon push ) , zpe must do the work to put precession  again to be parallel to external force. This is a way, how we can extract enrgy from  the zpe.
Esa
