Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
Turbo
Quote from: onepower on October 03, 2019, 06:33:25 PM
Turbo
All they would have to do is place the device in a steel box ie. Faraday cage to exclude Earths magnetic field/EM signals and they would know. I mean this is high school science 101.
This is strange as well, moving charges produce a magnetic field and a big explosion accelerating/compressing an absurd amount of charges in a small time frame produces a big magnetic field change. Granted an EMP weapon uses explosives to move the conductor carrying charge and it's associated magnetic field however the principal still holds. It does not matter how or why the charges are moved to produce a magnetic field change only that they do move. Again SM seems to be having a problem with what is routinely taught in high school science class. Hell my son made an EM disrupter and smoked a cell phone in grade 8 which isn't even classified as high school, lol.
In the end, at worst SM fits the standard profile of just another inventor who stumbled onto something they didn't understand and tried to turn it into a business for profit. It works until the environment goes to shit, the economy collapses, billions die a premature death and money becomes worthless... then it doesn't so much.
You can't just judge someone or something on like he should have know this or they should have known that, because my 8 years old son or the textbooks.
That's not what we are doing here we are trying to verify and confirm things, not debunk them with whatever we can find to throw into the ring.
Keeping an open mind is essential in this process.
My advice to you would be to take your son's textbook and give him some wire to play with in stead.
By the way they did test it in a metal box and confirmed that it still operated as before.
The fact that you seem to think that a Faraday cage blocks the Earths magnetic field is disturbing.
Did you miss some day's at science 101 ?
Turbo
Quote from: Jeg on October 04, 2019, 02:29:57 AM
Great video for visualizing the effects. Thank you!
I wonder if spark detectors can also sense the beta radiation along with alpha as i think that this is the case here.
I guess anything that helps ionizing the air up to the point of breakdown will do that.
And if it's really a close gap or high tension possibly even UV light.
Cadman
I'm trying to get the gist of the method straight, and maybe learn something here.
As I understand what has been written there is a coil in the shape of a ring (coil #1) that has another coil wrapped around it (coil #2). Coil 2 has a dc current in it to create a magnetic field. This field in coil 2 is basically shaped like a round tube. Centered inside this magnetic tube is coil #1. When coil 1 is properly pulsed it emits electrons, which are confined inside the magnetic field (tube) of coil #2 and aligned with the direction of the field inside #2. Then coil 2 is pulsed with a stronger current to drive the electrons back onto coil #1 and an increased current can then be taken from coil #1.
Is this correct so far?
Raycathode
Turbo
Quote from: Cadman on October 04, 2019, 09:53:02 AM
Very close.
Coil 2 is more oval or even a high rectangle shaped, because Coil 1 is not interleaved so the turns are wrapped in a specific way.
