Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
Quote from: groot on October 06, 2019, 09:47:07 AM
Maybe a bit too early but this will explain a lot in next steps :
https://www.youtube.com/watch?v=zrDxSM91Jcg
Yes this video  is amazing thank  you for that.
This is a lot to talk  about it but I'm on something  now
I'll be back...soon
Wesley
groot
Just as in video posted earlier.
Transmission line is my tesla coil ( top load and secondary coil ) at 1/4 wavelenght of 480 feet  and resonance frequency of 512 kHz.
Apparently my cheap scope  can picture this idea only when feed with square wave and i lack skill to observe sine wave this way.
thank you
stivep
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=imgres&cd=&ved=2ahUKE
wiRlfex3uTjAhVnuVkKHZm9Dm8Qjhx6BAgBEAI&url=https%3A%2F%2Fwww.biodyncorp.com%2
Ftools%2F450%2Fimpedance.html&psig=AOvVaw2GAepZpPzpzVpqdNpDhmvh&ust=1564854222455359  i
t will redirect you to
https://www.biodyncorp.com/tools/450/impedance.html - this link alone may not work  try  upper one.
Important for:
- Luc
-any other builder  of the Tesla  coil and  for Tesla coil Tx  Rx energy  transmission system form point A to B
- Tesla coil extracting energy  from Schumann waveguide builder
Mechanism explained in this link shows interaction of my body with Lightbulb  I was holding in my hand .
I was not touching  metal contact of the lightbulb.
https://youtu.be/XOTLfnMOSqQ?t=416
My body reacted as part of electrical circuit  and it was( reactively) - capacitively coupled to the lightbulb
And now forget about me and my body
Just take it as solution  that can be applied to any resonance circuit so
- the same mechanism can be applied to our Tesla coil.
Our goal is to  create TEM in TM mode
and we are using  the same elements of impedance:
( capacitive and inductive reactances and resistance )
to provide impedance match between Tx and Rx.
Or to  be more accurate what is the  relation of the:
phase angle and  resonant circuit  reactive components  XL and  Xc
The two of the components makes X(  the reactance)
The X and R(  resistance of the conductor) makes Z(  the  impedance)
That Z can be:
- our  body Z
or
- our wire in our coil Z
and/or
- our primary or  secondary  HV coil
and/or
- our primary or  secondary  HV coil and Top Capacitor
or
- any  of elements  of  the structure that in  summary makes  the total impedance of
Tx system or Tx/Rx pair connected  by use of interface
Types  of interface:
-e.g
Goubau  line uses  wire coated with   dielectric and that should be   named  the interface, but it is not.
- two dielectrics differing  with their  dielectric properties   such  as Teflon  and Polyamide  makes interface
- conductive medium such as  aluminum foil  and  air creates  interfaced as well
- lossy conductive  medium a such  as earth   and air creates interface too
and so on...
more is here:
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg539517/#msg539517
We also need to provide condition to our Tx where  the
two components of impedance cancel each other and our HV part
of Tesla Coil will be in resonance by that.
So simply by looking at the graph you can see how Phase angle  is responsible for other elements of impedance listed here (and/or  reverse).
look at  the  picture  below read everything  but don't read  words "human body"
and that explains what is  going on in Tesla coil
I hope that is  easy to understand.
So why do we need it?
Answer:
This is mechanism of Tuning of our Tx and Rx
Wesley
Wesley
gotoluc
Quote from: r2fpl on October 07, 2019, 07:47:00 AM
Two coaxial cable: https://www.youtube.com/watch?v=p4TVefHjk-U
Witajcie.
Nie jestem pewien, jaką część testu uważasz za interesującą?
Nie widzę, która to jest niebieska sonda, a która żółta sonda na oscyloskopie.
Zauważyłem 180 stopniowe przesunięcie fazowe pomiędzy wejściem i wyjściem, kiedy fala sinusoidalna jest powtarzana.
Proszę napisać po polsku, żebym mógł tłumaczyć.
Dziękuję
Hello
I'm not sure what part of your test you find interesting?
I can't see which is the blue probe or yellow probe on the oscilloscope.
I noticed a 180 degrees phase shift between input and output when sine wave is repeated.
Please write in Polish so I can translate.
Thank you
