Crystal Cell Research for Experimenter
Started by plengo, October 24, 2014, 11:36:59 AM
plengo
and a long time coming video packaged with findings in a very simple 3 steps progress showing the potential of this technology.
https://youtu.be/2m57x2CE0kk
e2matrix
Nice.   I couldn't quite understand what the center piece is made from in the video.  What type of metal and is it coated or treated with something?
    Ok I see after reading back a bit you may want to protect this process.   I have a question about the 'heart beat' you mention.   Are you seeing pulses from the battery as I see on your o-scope?   If so I have to ask if it is possible you are picking up EMF from your home?   Are the pulses the same rate as your power grid?   Just asking and not trying to reduce the discovery you have but since it is not mentioned I had to wonder if it has been considered.   In other words can you take your cell out in the wilderness away from any strong EMF sources and still see voltage on it from your meter.   I'm guessing you have already considered that but it would be good to state this is not the case - i.e. an antenna cell of sorts.
plengo
It is not 60 or 50 hz, so no, it is not the house.
I do carry my cell with me in my car when I drive for Uber/Lyft.
The black piece of metal is Magnesium (Mg) processed via Electrolysis. A 2 ml solution of H2SO4 (Sulfuric Acid) (car battery electrolyte), plus 300 ml of distilled water. Add Epson Salts until solution saturates at room temperature (25 Celsius).
Magnesium goes to the negative terminal and positive terminal goes to a Copper pipe touching the surface of the solution inside a container.
You have to perform the electrolysis many times in sections of 20 seconds. Clean the surface of the Mg until dry using a kitchen paper towel on each bath.
The final result will be similar to what you see in the picture. The one in the picture is very wet, just come out of the bath.
This piece once formed correctly will generate power, although extremely small, indefinitely.
Jimboot
Quote from: plengo on November 04, 2019, 03:03:16 PM
Wow I have to have a play with this. Thank you for sharing. Very interesting.
plengo
Please do participate and try. I am here to help everyone to get it running. It will run for decades.
