Steven Marks secret
Started by otto, October 07, 2009, 12:26:21 AM
Toolofcortex
Ok the researchers of the past were simply garbage.
Complete dog shits from 2008 when YT was in full swing.
Think of this circuit
You have 3 "wired or" MOSFETS sharing a transmission line. Maybe some of these mosfets were more distant to the line end/termination than the others Think of how weird it would be if the terminaiton was a loop, likewise, think of how it would be easy to adjust antenna size with just sme cheap foil that you can shorten and cut. How would you match a node to another node? Think..... I ask Question.
I almost have a toroid circuit, right here, of what I wanna try, a toroid what many frequencies and "control" coils.
Now a new thought, in the dynamics of a line charging event(point where reflections occur to then die out and let DC be DC according to specs of lines etc), Would it not be possible for many currents and reflections to meet at a specific point. Maybe, they can all meet in a big sphere point. with LARGE surface? Yes it will be an impedance missmatch and be itself a cause for reflection, but it just seems possible that perpendicular currents could occur.
At perpendicular angles this time. Wouldnt that be special?
But now, having a "node" is not all that fantastic in itself, because we know the try reside in a secondary process to those nodes.
Raycathode
Quote from: Toolofcortex on February 10, 2020, 09:07:36 AM
alloy duct tape with 2 layers and an insulator
Now a new thought, in the dynamics of a line charging event(the point where reflections occur to then die out and let DC be DC according to specs of lines, etc), Would it not be possible for many currents and reflections to meet at a specific point. Maybe, they can all meet in a big sphere point. with the LARGE surface? Yes, it will be an impedance mismatch and be itself a cause for reflection, but it just seems possible that perpendicular currents could occur.
At perpendicular angles this time. Wouldnt that be special? sure would be
Toolofcortex
Nah...
You match the stuff with another method.
You have 3 oscillators.
How do you match nodes.
Now they are all positive fed from the same side remember, and all use either P or N MOSFET. Probably P.
How you get... A good node, a good weird thing going on.
THINK! ALL THE BS YOU EVER SAID OR HEARD IS ALMOST THERE.
Toolofcortex
Imagine this fucked up scenario...
I tell you, I start thinking of these scenarios easily now.
If you understand that reflection happens, and nodes, you can imagine waves very easily and be creative with nodes and combinations, timing or other circuit.
Back to my scenario.
Perpendicular nodes on a circular plate, so 4 connetions...
Or maybe there could be 3 plates, one grounded plane, and 2 outside plates, wich would have perpendicular connections, so 2 connecions on 1 plate and 2 on the other.
2 pulsing coils near each face.
Maybe a toroid surrounding this.
Basically just weird experiments on the same build you know... How you you rip out the contrated charge out of a plate and hack the system?
MasterPlaster
