Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Quote from: kolbacict on March 23, 2020, 10:22:22 AM
I agree.
My coil is powered by a sine wave, approximately 80Hz.
https://youtu.be/X6143k9-epo
@Kolbacict,
I managed to detect the increase in speed over the background music in your video. I have a question: How are the magnet fields directed when the acceleration begins? Is the "Neutral Plane" directed towards the motor with the N S fields up and down?
You succeeded at showing a really cool A.C. magnet effect. George Chianiotakis demonstrates this effect with a "Reed Switch", but all his videos are pulsed D.C.
I want to ask if you can please redo the video with the background music turned down? This is an important video, you need to improve the quality to make the "Overunity" effect stronger to the viewer.
Imagine a washtub stator with NS magnet cubes, one on each leg. How much of the permanent magnet field changes leg position along with the A.C. signal? Your demonstration suggests that the A.C. field can dovetail and oscillate more then it's own flux by scarfing additional flux from the hand held magnet; The A.C. acting like a transistor gate for the PM fields you position in adjacency?
Matching the vibrator A.C. current Hertz with the ring frequency of the magnet generates the resonance that equals a large permanent magnet field shift.
synchro1
@Kolbacict,
We get the "Advantage of the Sum" when we match the A.C. frequency of the vibarator to the ring frequency of the permanent magnet. The electro-magnetic field adds together with the permanent magnet force in resonance!
kolbacict
When the coil is disconnected, the oscillations stop.  When shorting the coil too.  I think if i pass direct current through the coil result will be the same.
synchro1
Quote from: kolbacict on March 24, 2020, 12:44:17 PM
I don't know if we can hope for any results from that approach.
An 80Hz sine wave can very easily be generated with an online sound generator and amplifier. I plan on using the software on two Washtub stators and magnets.
Nunez runs Rodin Coils with this trick. This could easily generate the 6x power increase Brad achieved.
kolbacict
Is it possible  more about Marco Rodin's coil? Why did it make a noise ;) a few years ago, and then went into oblivion?
