TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
MACEDONIA CD
no ronote  i no play game whit all
listen i simple  if you translate this  you can read some good things and whill see that is not joke is real things  there you can see a formula  ho explane everthing  and you  can find the way to put this formula to make tpu  <<<< explane    you have two energy  first is  magnet fild  then second  is speed  if you any of this if you increase  if speed  or mag. filds  you can created power how you need >>>>
i say in my languege   this  you can find i way toincrase the mag . fild  whit so smlall energy  << i mean  elktri or  permanenet magnet ho whill need like a source energy only to start this   you dont need only elektric energy to start you make whit  only a small per. magnet  >> EXPLANE  AND LITLE HELP  TO ALL
WHAT WHILL HAPEND IF YOU PUT PERM. MAGNET TO MANY WIRES AND COIL  ONLY  A JUST A SECOND YOU CAN SEE A KICK
AND THAT KICK IS IMPORTANT TO MAKE 10000 OR MAYBE  MAORE  HO WHILL DEPENDET OF YOU HOW IS MADE  CONTROL COILS
  1 -- IF YOU STRAT WHIT MAGNET  THAT IS SOURCE ENERGY HO IS INDEPENDET OF CONTROL COILS  2
2-- IF YOU PUT BATERY  WHIT START JUST A SECOND WHIT DC V  .. THEN THIS DC GOES TO CONTROL COILS    AND YOU IS IMPORTANT  HOW IS MADE CONTROL COIL  THAT COILS  IF YOU FIND EXSATLY WAY TO PRODUCED 10000 OR MORE KICK JUST  WHIT ONE KICK
A THAT FIRST KICK IS NOT HOW YOU WHILL BE MADE YOU HAVE TO WAY TO MAKE FIRST KICK <<< BATERY OR PER. MAGNET>> THIS IS NOT VERY IMPORTAN WAY YOU WHILL HOW TO MAKE A KICK  >>> BUT IS VERY IMPORTANT  CONTROL COIL  NOTHING ELSE
AND IN THE END  YOU CAN FIND HOW TO PUT COLECTOR COIL TO CATCH TE MAG .FILD HO WHILL GENERATED CONTROL COILS
YOU SEE THIS PITURES I HAVE SEND ONLY THIS WAY TO MAY CONTACT MAGNET FILD WHIT ANTHER << I MEAN CONTROL WHIT  COLECTORS COILS  I SOON WHIL POST VIDEO TO SEE  AND  TONIGHT WHIL POS SIMPLE PDF  EXPLANE  BY
MACEDONIA CD
wattsup
@Roberto
Thanks you for your comments. I will look again at the coils.
@All
OK, I looked for some more goodies and found two.
1) There is in fact a coil#3 on leg #3 but it is not horizontal wound so the leg cannot go through the center. It is vertical wound and then taped to the leg #3. That is why when you see the image top view, there is nothing shiny showing like the magnet locations and the top of the metal box. That is also why this leg #3 has tape wrapped vertically. So he has coil #1 and #2 are horizontal wound and coil#3 that is vertical wound. Also Coil#2 has another device taped to the outer side as shown in the photos above. Keep this in mind.
Also, after more observation I would say the winds are as follows.
Coil #1 and #2 are 8 turns, two layers.
Coil #3 is 4 turns, four layers.
In all, I would say at this point each coil has 16 winds.
Also, it seems there is only one Litz going from the circuit to Coil #2, Coil#2 goes to Coil #3, then Coil#3 goes to Coil#1 and there is one wire going from Coil#1 to the circuit board. This means the coils are all in series, which would be logical if you were looking to build higher voltage.
2) This is a major freaker. When he is putting on the magnets, with his right hand, he puts the magnet on Coil#1 without any problem. He then transfers the second magnet form his left hand to his right hand and puts it on Coil#2, again without any problem. But for no apparent reason, he then approaches his left hand to the side of Coil#2 and you can clearly see his left hand index finger pushes on the device that is taped to the side of Coil#2. This is at 34:57. If you are not asked to notice this, you will not as it is done in the normal flow of movement. His heart must have been beating faster then ever as I am sure he did not want anyone to notice this. You have to see it to believe so by all means. Also to hear it because you can here a tic-tic sound as he pushed the switch. So all indications show that it is switch activated. It is also a funny coincide that this is the leg I had indicated may have some small batteries. Coincidence?
I will be revising the diagram to show these new observations.
More to come.....
Bruce_TPU
@ Wattsup
I personally believe he used at least watch size batteries in the small units, to start them, up to two to three 9 volts in the larger units.  This does not bother me at all, but it would seem that there was great concern on the part of UEC, that it would bother the investors and they would not understand.
This is just my personal opinion based on my own observation.  Also, none of the engineer reports speak of the units being started with a magnet.  No need for those guys to think otherwise, they understood the significance of SM's achievment based on the Watts per hour output and that NO BATTERY of the weight of the units could output the shown wattage.
You are doing good work!   ;D
Bruce
Earl
@Wattsup
I thought the openTPU had 4 coils spaced 90 degrees.  You only talk in your last post about 3 coils.
Earl
