Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
joaouchoa and 247 Guests are viewing this topic.
Raycathode
in truth unless one lives in India ZPE is a risky boniness, Nelson has given us a good bit of know how
and cleared up a lot of mudded water Ruslan has created in some ways mainly katcher frequency ect,
I'm not so sure I want to make a working device like that and probably wont I'm just interested from
an educational point of view.
Chris looks like he has a secret passion for blowing birds to bits on power lines  ;D
Regarding the repetitively repeating could it be a case of vaccinated with a gramophone needle
but in reality when will he publish new work ??
Still such is life and each to his own, so lets agree to disagree. And move on.
Raymondo
DavidWolff
Quote from: GeoFusion on April 17, 2020, 10:22:02 PM
                        AG
                  "so what's the missing link we are ignoring ?"
  What many didn't mention much,   B.E.M.F. energy
                Is the missing link. ;)
Do not focus on the conventional ways of getting energy out....
** edited post
You mention B E M F what sort of BEMF do you refer to from the tesla coil or perhaps a LOT  like Ruslanhas started to use ? did you notice the way round he had it and what looked like tuning capacitors ?
Now if we go back to the Katcher or Tesla coil a lot of guys have cut down on the winds however this
in my view increases the frequency to Mhz range but if you add too many capacitors the amplitude of the wave
almost disappears and getting such a device will make it almost impossible to get it to self oscillate.
I don't mean to be a critical person but T1000 when we ask a question never replies and or is missing.
There is also the Grenade does your device get hot ?   :D :D hmm i wonder why that is going on
and wasting any gained power ?
regards Dave
NickZ
   Dave:   Are you asking these questions because you are interested in building such a device? Or is this also for just an educational point of view.  T-1000 has answered me when I ask him something. But, he can tell you what has been said. He has not built up this device, and therefore has not practiced what he mentions. But, in any case he is helping to translate what he sees in the videos.
   And yes, my grenade does get hot at times. Doesn't the same thing happen to normal running transformers, when running on several hundred watts?
   The normal Kacher output running frequency at the antenna coil is from about 850KHz to about 2MHz, or so. With a voltage of around 3000v, to 10.000v. Mine runs at around 1MHz, and that can be adjusted up or down in frequency by simply adding or removing wire turns.
   The idea of now using controllable Kacher circuits, to pin down the exact sync to the grenade/yoke circuit, is what some guys are up to. Along with the idea of causing a delay in the pulses. But, this all still needs to be studied, and replicated to show IF there is something beneficial to that, or not.  As the grenade/yoke TL494 circuit is performing no magic by itself, and needs a Kacher HV pulse to sync with. Also, is needed a long thick 37.5m to 40m ground line which both circuits are connected to.
   Making both the induction circuits, along with a controllable Kacher circuit, is not easy. It takes much time and money.
Needed is also a scope, variable power supplies, along with a 24v feed back PS, signal generator, spectrum analyzer, a 40m ground line, many components, 200w to 1000w bulbs, and a lot of wire for the coils. Just for education purposes... cause it may not work, as expected, after all. So, this device is not for the faint of heart.
  Here is an image of what my device looks like, at this time:
DavidWolff
Regarding the Grenade you can wind the device any way information is shown in the Dally
data base and since It would appear in one of Donald Smith films Donald Smith shows how to obtain
amps to do this it is important that the winding should have zero inductance
and since the katcher is a off shoot of the bucking coil phenomena re Mr P Reva if you don't get zero
inductance you get waste as in heat a lot of heat.
Dave
NickZ
   The grenade has been wound by different people in different ways to test which way works best. And yes, the point in it's reversed windings is to self cancel or at least obtain a minimum value of inductance.  I stick with the schematics by Stalker, as being for me the most trust worthy. As it seems that most everyone else has a different agenda, concerning how to build this device. And they may not be showing or hiding some of the important and critical details involved.
  The Kacher has also got a ferrite rod before the antenna coil, that has reversed windings on it, along with all the other reversed winding on the kacher secondary coil, ferrite rod, and antenna. Yet, 10 to 15mm sparks or streams, can be seen on the antenna coil, after all those reversed turns.
   I think that the following video was made by Ruslan, at least that's who it sounds like to me.   https://youtu.be/zbfsdamSbXw
