All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
Like this; I can wave a magnet stack and get propulsion with this spoke arrangement.
synchro1
The magnet spokes are programmed ceramics. This top ring spins frictionless with no cogging.
The poles once aligned can be powered from the under side at 45 degrees by a pulse coil.
synchro1
The pulse coil would need to look like this at 45 degrees; A bit awkward, but the position delivers a "Quick and Dirty" high speed frictionless bearing. All it needs is a rubber band to press the magnet spokes in place.
Magwood
Great work guys. I started my setup tonight and it spins very nice so far. I must admit I spent too long out in the freezing shed tonight playing with magnets. Good excuse to my cnc and disc sander circle jig.  :) If it doesn't work out I'll use parts for a wind generator.
Airstriker
You should use only non-magnetic materials for shaft, bearings and angles. Using ordinary ball bearings won't work - the balls will get magnetised and introduce pretty much "friction". Ferromagnetic shaft/bearings/angles It will also route the magnetic field where you don't want it to go.
